AX5 won't shift into 1,3,5th gears - JeepForum.com
post #1 of 25 Old 11-03-2013, 06:37 AM Thread Starter
bartlett93yj
Good Morning
I installed a used transmission last night in my 93 YJ 2.5L (the PO told me it shifted fine). It has the internal slave cylinder. When I went to shift on the test drive after finishing, I can't get it go into 1,3, or 5th gears. 2, 4, and R work great and shift fine. I installed a 5th gear collar when I had the new (used) transmission to prevent that gear from sliding back.
Has anyone had something similar happen to them? I don't know if it's a problem with the shifter or the transmission. Does anybody have any suggestions? THanks for any advice!
luke
bartlett93yj is offline
post #2 of 25 Old 11-03-2013, 06:42 AM
BrandonYJReed
When I blew up my ax5 I lost 1,3, and 5. Mine would go into the gear but nothing would happen. I only had 2,4 and R to drive with...
-1990 YJ, 2.5L, AX-15, lifted, locked, on 35's.
-1999 XJ, 4.0, AW4, lifted 4.5", JK Rubi take offs.
BrandonYJReed is offline
post #3 of 25 Old 11-03-2013, 06:50 AM Thread Starter
bartlett93yj
Thanks Brandon- Mine doesn't feel like it is engaging into 1,3,5 gears. Did yours feel like is was "clicking" into gear, just not working? Thanks.
post #4 of 25 Old 11-03-2013, 07:13 AM
BrandonYJReed
Yes I could feel the shifter drop into the gear, the jeep just wouldn't physically move when in it.
post #5 of 25 Old 11-03-2013, 07:19 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The pivot pin that holds the shift arm in the rear case is in backwards.
The hole in the end of the pin must face the transfer case. Also, the threaded bolt hole in the pin has one side where the threads are recessed, the recess faces up.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 25 Old 11-03-2013, 08:05 AM Thread Starter
bartlett93yj
You the Man Mean Max!!! I'm on it. I'm gonna dig and I'll report back.
Thanks!!!
luke
sad thing is, I even remember taking the mental note so I didn't put it back in backwards!!! oops.
post #7 of 25 Old 11-03-2013, 10:03 AM Thread Starter
bartlett93yj
Hi Mean Max- I just got done digging into it and it appears that the pivot pin is in right (I think). The second picture shows how it was positioned in the transmission. Is there anything else that might prevent it from shifting up into 1,3,5? Thanks all!
luke
post #8 of 25 Old 11-03-2013, 10:29 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Your pics show it as being installed properly, so I'm surprised that you're having your issue.
It's the ONLY thing that 1st, 3rd, and 5th have in common, with regard to shifting. Each one utilizes a different shift rail to accomplish it's task.
Got pics of the 5th gear retaining collar that you installed?
Max
Mean Max is offline
post #9 of 25 Old 11-03-2013, 11:01 AM Thread Starter
bartlett93yj
Sure thing Max- Is there a way I could have screwed up the Shift lever housing. May I have not gotten something lined upright? The image of the shift lever housing you posted above shows the cup where the shifter ball sits closer to the engine. My shift lever housing has the "cup" part nearer the rear. ...or...
Below are some pictures of the collar I got from Consolidated Transmission (Florida). I installed it though my C clip was not broken and 5th gear looked pretty good. The last photo is looking down through the top of the transmission. Do you this that this might be impeding the shifter moment and not allowing it to move into those gears? Thanks again! luke
post #10 of 25 Old 11-03-2013, 11:45 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
The pic I posted was an AX-15 shifter, and it IS opposite of the AX-5 with regard to where the hole is. Good eye for spotting that!
The orientation of the hole in the pivot pin (hole facing rearward) is the same for both models however.
I'm still puzzled over where the interference is. Is it possible that the shift arm (attached to the pivot pin) is contacting the clip retention collar?
Max
Mean Max is offline
post #11 of 25 Old 11-03-2013, 11:52 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
This pic is also of an AX-15, but the same part exists on the AX-5. It's a detent ball & spring for the shift rail that extends into the rear housing.
Are these parts installed properly?
Max
Mean Max is offline
post #12 of 25 Old 11-03-2013, 12:00 PM Thread Starter
bartlett93yj
I couldn't see or feel anything that looked like the fork (shift lever housing) is running into that collar. I am kind of leaning toward pulling the back of the tranny housing off, removing that collar, and then putting it all back together. Or am I missing something else that could be the cause?
When putting the fork/shift lever housing back in, is there a certain position it needs to be in to get it all to work? Thanks!
luke
post #13 of 25 Old 11-03-2013, 12:09 PM Thread Starter
bartlett93yj
I'll go and pull that ball and spring out and reinstall. I thought I installed them properly but I'll double check. I believe it was a T40 bolt. I believe there is one on the passenger and driver side.
post #14 of 25 Old 11-03-2013, 12:12 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
That's what I would do, try assembling it without the clip collar.
I make sure the ends of all the shift rails are in neutral prior to assembly, but that's really all there is to it. If the shifter operates 2nd, 3rd, and reverse, then the shifter is already properly engaging all of the shift rails.
Max
Mean Max is offline
post #15 of 25 Old 11-03-2013, 12:13 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Only the passenger side requires removal/installation during teardown & reassembly.
Max
Mean Max is offline
shifting problem
