AX5 where do ya put the oil? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > AX5 where do ya put the oil?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSavvy Billet LED Tail LightsWant to be able to SEE? DOT Approved Headlights for under
Unread 10-31-2014, 05:17 AM   #1
halmc
I'm embarrassed to say that I can't find the hole for adding oil to the AX-5 transmission. ('92 Wrangler, 2.5L)
Can anyone tell me in detail where it is before I go to the work of removing the sheet metal to which the shift boots attach?
Evidence is the Kryptonite of the Pious
halmc is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 06:01 AM   #2
Mambo_Dave
This is the AX-15, but you may see what you're looking for.
https://www.youtube.com/watch?v=9t_U...5baoRIzLeFE_AQ
Mambo_Dave is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 06:12 AM   #3
Feetwet
Enjoying the Ride
Feetwet's Avatar
The AX5 fill plug is about halfway up the Trans casing on the PASSENGER side, about 6" back from the front edge of the skid plate. Takes a 15/16" box wrench, just like the drain plug, which is bottom, center, front.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet's Ford 8.8 Axle Teardown/Rebuild/Install
AX5 Output Shaft Seal Replacement
Hand Throttle Install
AX5 Vent Install
Feetwet is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 07:10 AM   #4
halmc
Excellent! Is it easier to get to with the sheet metal out of the way -- the sheet metal to which both shift boots are attached, and through which both shift levers stick?
Unread 10-31-2014, 07:13 AM   #5
Wrangler95CSA
If you can reach if from the top, that's a much easier and cleaner way to go about doing it, yes.
1995 Emerald Green Wrangler YJ 2.5L, AX-5, NP231 SYE, 33" x 12.50" X-terrains, 6" ProComp CSC, 4.88's F&R, K&N Intake, Banks Power Exhaust Manifold & Cat Back, MagnaFlow Cat, AirAid Throttle Body Spacer, Rock-It 60MM Throttle Body, Mean Green Alternator, Reverse Glow Halo Gauges, JKS Quick-Disconnects, Energy Suspension Body Mounts, Warn Rock Crawler Bumpers F&R, Warn Spare Tire Carrier, Warn 9.5ti, Brown Dog Motor Mounts, Flow-Kooler Water Pump
My RigRater Score: 501RRv1.0 with a BOA of 21.30
Wrangler95CSA is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 07:30 AM   #6
halmc
Thanks!
Unread 10-31-2014, 08:20 AM   #7
halmc
Got it! Thanks to your excellent instructions.
Unread 10-31-2014, 08:26 AM   #8
Wrangler95CSA
Try this:
Unread 10-31-2014, 09:53 AM   #9
MJDriver
MJDriver's Avatar
Just make sure you don't pull out the bolt labeled "Do not remove" (stamped on the bolt head).
Current - 1993 Wrangler 2.5 - mostly stock
Previous - 1989 Comanche Pioneer 4x4 Long Bed/Metric Ton Pkg
4.0, AT, D44 w/ Trak-Lok RIP
MJDriver is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 07:26 PM   #10
1320yj
Fill plug is located on the passenger side in the rear back past the mid plate , the only 15/16 plug on that side.
I don't know why the plug on the drivers side is marked "DO NOT REMOVE" other than the fact it is much lower than the fill plug , however removing the plug wont hurt a thing other than under filling the transmission.
1995 2.5 5Speed SOA 33x12.50 Mud Rovers
1320yj is offline   Reply With Quote Quick reply to this message
Unread 10-31-2014, 07:42 PM   #11
Mark05059
wouldnt matter if they did. It wouldnt hurt anything
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
