Ax5 transmission trouble - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ax5 transmission trouble
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!Memorial Day Sale at Under Cover Fabworks! 15% Discount o
Unread 08-05-2012, 09:32 AM   #1
Nickmverr
I'm having problems with my 2.5 liter 1990 yj. I just did the whole exhaust system, it ran fine for a day or too, now there's an awful notice coming from the transmission.. It sounds like a grinding noise, it happens in neutral, but the noise stops when I press the clutch. Please, before I pay to pull the transmission, does anyone have any idea what this is?? And also its been idling high and running rough in general, any way to fix the idle??
Thanks!
Nickmverr is offline   Reply With Quote
Unread 08-05-2012, 09:37 AM   #2
UltimatE
Resident Audio Guru
UltimatE's Avatar
Is there any problem driving or shifting?
Since the noise goes away when you press in the clutch pedal, it could be a clutch issue as well. eg: Bad throw out bearing.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline   Reply With Quote
Unread 08-05-2012, 09:39 AM   #3
Jeepsr4me
Thanks!
Check around and see if all vauum hoses are on and not broken.
Has it been tuned up lately, plugs, wires, cap and rotor do wonders for idle and power.
But your other issue is more than likely the throw out bearing. Might as well do the clutch and pilot bearing too.
Jeepsr4me is offline   Reply With Quote
Unread 08-05-2012, 09:40 AM   #4
Nickmverr
There's no problem at all shifting, it's strange.. We thought about the throw out bearing, but that noise usually happens when you press the clutch in, right?
Unread 08-05-2012, 11:03 AM   #5
UltimatE
Resident Audio Guru
UltimatE's Avatar
When the clutch is out, there is no pressure on the bearing, and that is when the noise happens. When the pedal is pressed in, it loads up the bearing and stops the noise.
-Matt
White '94 YJ Sport
Unread 08-05-2012, 11:57 AM   #6
Jeepsr4me
yeap, give it long enough and it will do it even when pressed in. Ever see what a throw out bearing looks like full seized up?
Unread 08-05-2012, 01:54 PM   #7
Kamikaze
Since you will be pulling the tranny, may I suggest centre force dual-friction clutch? Also since your ax5 is 1990, it the slave and throwout bearing are one unit. Have fun.
Live Free, Laugh Loud and be Friendly.
Kamikaze is offline   Reply With Quote
Unread 08-05-2012, 05:24 PM   #8
Mean Max
Don't poke the bear
Mean Max's Avatar
I wouldn't recommend any Centerforce clutch. They're well suited to high rpm/high load situations (like race cars) but they're nothing but completely wasted money on Jeeps.
LuK clutches are better suited than almost any other brand, and the less expensive LuK RepSet will do fine.
Max
Click here to see all of my different albums on Photobucket.
Choose any album to see all of my pics!
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline   Reply With Quote
Unread 08-06-2012, 08:29 PM   #9
Nickmverr
Thanks, my yj is up on jacks and we are taking everything a part slowly but surely, thanks for all the help, I'll let you know what the final outcome is!!
Nick
Unread 08-06-2012, 08:48 PM   #10
Luuca
Luuca's Avatar
be sure to have the flywheel inspected and/or resurfaced since you're in there already. any fluid leaking from the bell housing?
Visit my blog: A Daughter, A Dad, and a Jeep....Busted Knuckles.
Yellow Jeep Club Member #91
Then try posting in the street jeep section. They've got a whole bunch of useless garbage stuck on their jeeps.
Originally Posted by jbolty
This thread is not tech and is too much of a train wreck to move anywhere else.
Luuca is offline   Reply With Quote
Unread 08-06-2012, 09:27 PM   #11
ltrail
1984 XJ Cherokee
give the input shaft a good shake. If it flops all around get an ax15 and love a real transmission lol. I've had bad experiences with 4banger trannys.
84 xj 350ci(in progress) 700r4/241, D44/9 4.88's, linked, spooled
92 wrangler 4.0 31's DD
95 xj wifes toy Stockish for now...
ltrail is offline   Reply With Quote
Unread 08-06-2012, 09:34 PM   #12
trboxman
Stalking fools
trboxman's Avatar
1987 YJ Wrangler
FWIW, the clutch kit I bought from NAPA was a LUK clutch kit in NAPA packaging. Not for an AX5, but you might want to check because it was way cheaper than anywhere else I could locate a LUK clutch.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline   Reply With Quote
Unread 08-07-2012, 08:03 AM   #13
dvr6
Yep I just bought one for an ax-5 from NAPA. The counter said the parts in the kit are made by the oem manufacturer for Chrysler including the internal slave and are sold as NAPA. 130 for the deluxe rebuild kit...
dvr6 is offline   Reply With Quote
Unread 08-08-2012, 09:05 AM   #14
Nickmverr
I'm working on it all day today.. Do you guys have any tips on pulling the transmission?? I'm taking your advice and getting the clutch kit from napa. I just need help, I know there's 4 bolts, is there any tricks to getting it and t-case out easily?
Nick
Unread 08-08-2012, 09:18 AM   #15
Xpress
Xpress's Avatar
I always pull the t-case and tranny in one go. Guess it would be easier just to pull one at a time, that way you can manually pull them off? They don't weigh too much each..
My 5.2L Build thread
-1989 Jeep Wrangler 2.5L, soon to be 5.2L
-2004 Kawasaki KLR650
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
L.E.D. Guru
Xpress is offline   Reply With Quote
