AX5 transmission from 89 to 94 - JeepForum.com
post #1 of 4 Old 03-04-2013, 08:17 AM Thread Starter
k_linx
My brother has an 89 YJ 2.5. He needs a new transmission. He got one from an 94 YJ. He noticed that the bell housing is different and that it has an external slave cylinder. Will the 94 transmission still work if we swap out the bell housing?
Thanks,
k_linx is offline
post #2 of 4 Old 03-04-2013, 08:18 AM
grandboost98
It will work, you just need to swap out all the clutch components too
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #3 of 4 Old 03-04-2013, 08:45 AM
jokerchief462
Finish it up with an external when you reinstall worth it all the way.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 4 Old 03-05-2013, 05:46 AM
jeep63
jeep63's Avatar
I just did this on my 91 w/2.5. Definitely the way to go. If you can find a new master cylinder complete with fluid you do not even have to bleed the system. A simple bolt on process.
jeep63 is offline
