Ax5 trans trouble no gears work but 4th - JeepForum.com
post #1 of 3 Old 08-26-2011, 09:09 PM Thread Starter
Micah1234
When using 1,2,3 the trans made a whining sound driving on highway using 5th and the trans made grinding noise and didn't go anymore found out 4th still works was able to drive it 120 miles in 4th to get home I understand the 4th gear is 1:1 but what should I look for to see why all the other gears including reverse dont work? Thanks
Micah1234 is offline
post #2 of 3 Old 08-26-2011, 10:17 PM
tommbstone
I have an extra Ax5 for sale that works fine but the ship would be to much i think.
tommbstone is offline
post #3 of 3 Old 08-26-2011, 11:36 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
ALL gears require the input shaft to drive the counter shaft in order to transfer power, all EXCEPT 4th gear. I suspect you have a bad input shaft or counter shaft.
I would recommend buying a used AX5 & rebuilding it. The trouble with rebuilding yours is that there may be a LOT of collateral damage internally.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
having trouble selecting gears OnlyOneKeano YJ Wrangler Technical Forum 15 12-04-2010 12:04 PM
'95 yj trans trouble Paul04TJ YJ Wrangler Technical Forum 2 04-30-2010 10:04 AM
Trouble Shifting Gears AX-15 muddymoose TJ Wrangler Technical Forum 7 07-21-2008 10:47 AM
Trans Trouble matt1751 TJ Wrangler Technical Forum 0 05-15-2008 09:06 PM
Trans trouble 4wheeler98 TJ Wrangler Technical Forum 7 01-02-2007 08:50 PM
