AX5 Shot 2nd Gear Synchro... fluid change reccomendations needed! - JeepForum.com
post #1 of 7 Old 02-21-2009, 09:14 AM Thread Starter
MikeyJ
My 2nd gear synchro is worn and scrapes into gear, I was wondering if I put some good fluid into the tranny that it will calm/quite this scrape? I know the tranny fluid hasn't been replaced in a while! Whats the best fluid to run for my AX5 to quite this scrape?
and of course... where is the drain and fill plugs?
MikeyJ is offline
post #2 of 7 Old 02-21-2009, 11:07 AM
sitdwnandhngon
1987 YJ Wrangler
If it's already shot there is no miracle lube thats gonna fix it. As far as that transmission goes though most off the self gear lubes have additives in them that eat syncros.
You need a gl-3 or gl-4 compliant lube.
Personally I use 10w40 motor oil. It's virtually the same stuff but with no additives. I made the switch last year and it shifts great and I haven't had a single problem.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline
post #3 of 7 Old 02-22-2009, 07:53 PM
chuckeroni
Take that badboy apart and swap in new synchros.Its easier than you think.Are you sure the mainshaft main bearings arent toast?
chuckeroni is offline
post #4 of 7 Old 02-22-2009, 08:24 PM Thread Starter
MikeyJ
Its my DD so I can't do that... pretty sure its a shot synchro as the PO had a mechanic check it out and quoted him 5k for the rebuild. It only scrapes into 2nd whether its a downshift or upshift.
MikeyJ is offline
post #5 of 7 Old 02-22-2009, 08:41 PM
yjwrangler08
my 2nd gear synchro was making noise, and i replaced the fluid with some fresh 80w-90 gear lube and added a tube of synchromesh, it made the grind almost disappear. it only happened on downshifts if i didnt do it right.
hope this helps i know what its like to try and keep a yj daily driver in one piece.
*95 Wrangler, 4in RC lift 33in procomp muds. 350 Chevy TH350 tranny. bedlined interior*
yjwrangler08 is offline
post #6 of 7 Old 02-22-2009, 08:44 PM
JohnRodriguez
you can try and use some amsoil manual transmission lube, part#MTGQT. I've used it for the last 3 years. my main problem was shifting in cold mornings. before i used mobil1 75w90, but it was not a syncromesh and amsoil is.
89 Wrangler, 2.5L TBI, D30 Truetrac 4.56 gear front, Super 35 4.56 gears rear, 31" BFG Mud's, 15x9" weld racing pro-stars XP's, 2.5" rancho and 1.25" shackels, superior axles. rear wilwood disc brakes
2008 wrangler x unlimited. Stone white. Motech 5.3L LS Chevy
JohnRodriguez is offline
post #7 of 7 Old 02-22-2009, 09:26 PM
sitdwnandhngon
1987 YJ Wrangler
5k for a rebuild. Thats nuts. Go to a yard and grab a used one for a few hundred bucks.
4.2 has 0.2 more!
Write up needed for transmission fluid change billabong266 TJ Wrangler Technical Forum 3 10-13-2009 04:43 PM
NVG1500 Transmission. Fluid needed for change? BENGRFF TJ Wrangler Technical Forum 2 10-10-2008 06:01 PM
synchro gone? 2nd and 4th gear killas1mo TJ Wrangler Technical Forum 7 03-06-2007 08:02 PM
Fluid change after gear breakin hkiss96 TJ Wrangler Technical Forum 3 08-11-2005 10:30 AM
2nd and 3rd synchro shot at ~60,000 miles??? Greencar YJ Wrangler Technical Forum 5 05-30-2004 11:34 PM
