AX5 Shifter into AX15 - JeepForum.com
post #1 of 4 Old 04-12-2012, 11:27 PM Thread Starter
Rynfw100
Now, I've searched, and got mixed replys on this subject. My story is, I'm doing a V8 swap, using AX-15 from a 97 TJ, and want to reuse the Shift Stick from my AX-5.
Now, I have both of the Shifters, but the TJ one is bent differently, and the PO of the AX-15 JB welded some Train Bearing on the end as a shift knob (Cool Idea, but no.) Is it possible to take the bottom "Nub" thing from the bottom of the TJ shifter and put it on the end of the YJ shifter without issue? Or is there some other way to get the YJ shifter to work with the TJ transmission?
My 5.2L V8 swap and Jeep build:
http://www.jeepforum.com/forum/f12/1993-2-5l-jeep-wrangler-build-5-2l-swap-1210512
Rynfw100 is offline
post #2 of 4 Old 04-13-2012, 09:23 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The top and bottom of the shifters are two parts, at the square tube. The trans came with the bottom from the trans mfg, and the top was added at assembly, different tops for different vehicles over the years. With a good vice and some finesse (read BFH), you should be able to pull the two apart and swap the 'good' top onto the proper bottom. The top and bottom just slide into each other. Some PB Blaster may help.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 4 Old 04-13-2012, 09:33 AM Thread Starter
Rynfw100
Cool, Thanks.
I'll go warm my BFH up.
Rynfw100 is offline
post #4 of 4 Old 04-14-2012, 02:18 PM Thread Starter
Rynfw100
Here's an update for people who are searching for this in the future. Check out the FAQs, the one about removing the shifter lever from the shift stick. That's basically how I did it.
I used a pickle fork (took longer to find the damn thing), A couple squirts of PB blaster, and a vice. I just yanked on the pickle fork after getting the shift lever in the vice, and it popped right off (see: almost fell on my butt). Just switched the isolators and switched the AX-15 shift tower onto the AX-5 shift stick.
Rynfw100 is offline
ax15 shifter loose? 88yj YJ Wrangler Technical Forum 7 09-05-2014 04:24 AM
would an ax5 shifter work on a ax15 aaronm YJ Wrangler Technical Forum 2 02-29-2012 05:51 PM
Is the Shifter from a YJ AX15 the same as TJ AX15? capone1680 TJ Wrangler Technical Forum 4 11-16-2009 05:31 PM
ax5 shifter on a ax15? Brian2o0o YJ Wrangler Technical Forum 8 03-12-2009 02:08 AM
ax15 shifter 2cjs YJ Wrangler Technical Forum 3 09-22-2002 10:13 AM
