ax5 parts on my ax15 swapability?? - JeepForum.com
post #1 of 6 Old 02-09-2013, 08:36 PM Thread Starter
95yj0645
Doing a 4.0 swap on my 95 wrangler.. obviously upgrading to an ax15 but it is internal slave cylinder. Can I use my ax5 bell housing and bearing retainer to do the external slave cylinder conversion?
95yj0645 is offline
post #2 of 6 Old 02-09-2013, 08:41 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No, you cannot.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 6 Old 02-10-2013, 07:29 AM
Cobra Jeep
You can reuse the slave cylinder and release fork, those are the same. But you will need a external slave 4.0 AX15 bellhousing. Bolt patterns between the engines and transmissions are completely different. The 4cyl ones will not work.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #4 of 6 Old 02-10-2013, 01:57 PM Thread Starter
95yj0645
Thats what I needed to know thanks. Will I need a different master cylinder if I keep the internal slave cyl for now?
95yj0645 is offline
post #5 of 6 Old 02-10-2013, 02:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
No, you can use the one you already have.
Max
Mean Max is offline
post #6 of 6 Old 02-11-2013, 05:31 AM Thread Starter
95yj0645
Thank you Max.
95yj0645 is offline
