AX5 Output Shaft Seal Job w Pics - Page 3 - JeepForum.com
post #31 of 50 Old 07-17-2011, 08:38 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Glad it worked out for you.
Thank you for the kind words. I appreciate your comments.
I know I can speak for Max, and many others on here, when I say that these writeups are fun to do and it makes it that much better when someone can use them to save a bundle on repairs and learn about their Jeeps at the same time. Taking some of the mystery out of these jobs can give you the confidence to tackle bigger projects in the future.
That's what its all about, right?
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #32 of 50 Old 07-18-2011, 03:23 PM
Siva283
Yes they definitely help boost confidence I know they did for me. I have always been afraid of transmissions but since I didn't have to take it apart I was on the fence and this write up gave me the confidence to do it myself. Saved me a few hundreds bucks that way too thankfully. I am still at one income since my wife got hurt 2 months ago and will be out of work another few months so things are really tight right now
Ask me how I know...
Siva283 is offline
post #33 of 50 Old 07-18-2011, 06:48 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Keeping a good thought for the Wife.
In the meantime...Read, read, read. Start with the YJ FAQ's pinned at the top of this subforum. Familiarize yourself with the engine bay, fuel system components, steps for routine fluid changes including differential maintenance, brake system etc.,etc.
The more you do for your Jeep the less you'll want someone else wrenchin on it!
Feetwet is offline
post #34 of 50 Old 12-27-2011, 08:49 PM
ashland82391
Just got home a couple of hours ago from doing this very same job. It took me a month to have the right seal sent to me. This thread makes me want to take the transfer caseback off to chech to see if my plug is there lol.
ashland82391 is offline
post #35 of 50 Old 04-14-2012, 04:11 AM
rozco
thanks for the write up. now i have to paint my tc when i do my 249>242 swap
93' ZJ - 5.2L. 4.5" IRO lift. front long arms rear short adjustables. bilsteins. daystar bumps. 33" KM2's. rancho ss. rc quick discos. flowmaster 10 series.
rozco is offline
post #36 of 50 Old 04-14-2012, 10:31 AM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
That blue paint is holding up great! Easy to hose off and looks GOOD!
Glad to see this thread is still helping folks out.
Shout out to Mean Max for his invaluable input.....
Hi Max!
Feetwet is offline
post #37 of 50 Old 04-14-2012, 05:31 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Hi Max!
Howdy Doc!
Good to see that old threads & old friends are still kicking!
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #38 of 50 Old 04-14-2012, 06:10 PM
AC_Spiderman
Wow perfect timing, I just picked up a new to me TC and this makes it look easy peasy to swap.
I didn't even have to search... This Old Thread and all it's Pics are perfect THANKS GUYs!!!
AC_Spiderman is offline
post #39 of 50 Old 07-01-2012, 03:14 PM
scapa5150
Spot on write up and pics. I think your count was off though... I do believe it's 2 million turns an 1/8" at a time.
scapa5150 is offline
post #40 of 50 Old 07-01-2012, 07:27 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
Ehhh..a million here, a million there, it's all quality time spent under the Jeep....
Feetwet is offline
post #41 of 50 Old 09-21-2015, 08:29 AM
DirectMatrix
Would a bad output seal cause oil spray onto the muffler heat shield, muffler and underside of the body behind the t-case above the axle? Is there anything else back there aside from the rear diff that is fluid filled? You can see the oil spray in the pics.
Any help would be appreciated.
~DM
DirectMatrix is offline
post #42 of 50 Old 09-21-2015, 09:55 AM
JP4VPI
My undercarriage looks just like yours. I definitely am leaking from the rear output seal on the tranny. I just haven't worked up my courage to try the repair yet lol.
JP4VPI is offline
post #43 of 50 Old 09-22-2015, 06:57 AM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
If it IS leaking from the Trans/TC seal, make sure you stay on top of the transmission fluid level until you replace that seal.
Bad things happen when the tranny has no juice in it.
Feetwet is offline
post #44 of 50 Old 09-22-2015, 07:42 AM
DirectMatrix
I'm about 95% done with an engine rebuild in my YJ... just waiting on a few odds and ends. While I'm waiting, I pulled the TC last night, drained it and the tranny (was gonna change the fluid anyways), and ordered all new seals. For < $30, it seems worth the piece of mind especially because I can't drive it just yet anyways.
With the TC out, I'll be taking a page out of Doc's book and cleaning/painting it as well as the tranny. Might as well make it pretty while I wait!
I've also got all the parts for the hand throttle mod so I can keep the engine at higher idle during the initial startup to make life a little easier.
Thanks for both those write up's, Doc.
~DM
post #45 of 50 Old 09-22-2015, 03:37 PM Thread Starter
Feetwet
Enjoying the Ride
Feetwet's Avatar
You are entirely welcome.
Glad the info was put to good use.
Feetwet is offline
New AA SYE--Now output shaft seal leaking moparjunkee TJ Wrangler Technical Forum 6 07-05-2011 08:46 PM
Rear output shaft seal Jeepfan Jeff YJ Wrangler Technical Forum 3 04-26-2010 12:14 PM
Replaced output shaft seal. ?'s Cards89YJ YJ Wrangler Technical Forum 5 02-20-2010 08:42 PM
New seal for output shaft on 231? blacktjsport TJ Wrangler Technical Forum 4 11-30-2006 03:37 PM
Output shaft oil seal Slim YJ Wrangler Technical Forum 5 03-26-2003 12:38 PM
