Ax5 interlock pins question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Ax5 interlock pins question
*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*Component speaker deal for your dash - NalinMFGOffset Tie Rod Kit From RuffStuff!
Unread 08-15-2013, 05:04 PM   #1
tloftin86
Rebuilding my transmission in my jeep and I put all the shafts back in and balls but now I have 2 little cylinder type interlock pins and have no clue where they go, even looking at the breakdown it doesn't show where they go, has anyone done this before and know?
tloftin86 is offline   Reply With Quote
Unread 11-14-2013, 07:34 AM   #2
biggunn
I'm sure you have it back together by now but here is a diagram. If they are small and oblong I believe they go in the holes in the shafts themselves. If they are the larger oblong bearings they go in the cast iron interlock gaps between the rods.
biggunn is offline   Reply With Quote
Unread 11-16-2013, 12:57 AM   #3
Wiggins3rd
Hey I just finished rebuilding my AX5. The 2 pins go in the shift rails
I might have a picture of it on my build
http://www.gatrailriders.com/GTRForu...?topic=11511.0
Wiggins3rd is offline   Reply With Quote
