ax5 input shaft question - JeepForum.com
post #1 of 3 Old 08-27-2011, 03:11 PM Thread Starter
dhc6
Hi All,
I just picked up an 91 ax5 for 35 dollars. He said it worked great before he removed it to upgrade to a 6cyl engine and a ax15. Is it normal to have sideways movement of the input shaft? The shaft that goes into the clutch assembly. If not it must be the front bearing? I can move it sideways about 1/2 inch in all directions. Thanks for all your help.
dhc6
dhc6 is offline
post #2 of 3 Old 08-27-2011, 03:50 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, it is normal to have a fair amount of slop in the input shaft. The pilot bearing in the crankshaft holds it perfectly once it's installed.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 3 Old 08-27-2011, 04:07 PM Thread Starter
dhc6
Max
thanks
dhc6 is offline
AX15 swap question! Larger input shaft! Jeepfeud TJ Wrangler Technical Forum 4 07-31-2011 09:29 PM
Quick Transmission Input Shaft question MikNov TJ Wrangler Technical Forum 3 06-20-2009 10:34 PM
Tranny input shaft seal question lah2420 YJ Wrangler Technical Forum 3 03-09-2008 02:41 PM
ax-15 input shaft question... TJ_Firefighter TJ Wrangler Technical Forum 6 05-06-2007 11:44 AM
Np231 input shaft question?? lamarjk2 TJ Wrangler Technical Forum 1 02-10-2006 11:35 PM
