ax5 gear oil!!!! - JeepForum.com
post #1 of 22 Old 07-12-2013, 07:00 PM Thread Starter
Mattias25
ax5 gear oil!!!!
is this gear oil safe for my ax5? it's royal purple 75w-90 max gear
http://shop.advanceautoparts.com/web...rchTerm=75w-90
Mattias25 is offline
post #2 of 22 Old 07-12-2013, 07:09 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Cheap 10w30 from walmart, save your money for real mods.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 22 Old 07-12-2013, 07:35 PM
TSEJEEPERS
Yep
The only other thing I would use would be Pennzoil Synchromesh.
http://www.pennzoil.com/other-car-pr...mission-fluid/
What ever you do use make sure it is yellow metal compatibility.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #4 of 22 Old 07-12-2013, 09:25 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
x2 on the synchromesh.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 22 Old 07-12-2013, 09:43 PM
rodgers3
x2
rodgers3 is offline
post #6 of 22 Old 07-13-2013, 12:14 AM
ashland82391
10w30
ashland82391 is offline
post #7 of 22 Old 07-13-2013, 05:56 AM
greyarea
I am running 80-90 GL-4 in my AX-15. I got it at NAPA.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #8 of 22 Old 07-13-2013, 07:12 AM
Mr.B
Mr.B's Avatar
Do some searching on here about Pennzoil Synchromesh, and AX-5's. Then ask yourself if you want to run anything else in it. I know I won't.
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 22 Old 07-13-2013, 07:19 AM
StanF
Originally Posted by rodgers3
x2
x3 - cheapest Walmart 10w30
StanF is offline
post #10 of 22 Old 07-13-2013, 09:09 AM
metalhead
2011 WK
The spec for the ax5 is 75w-90 gear oil. Why is 10w30 motor oil being suggested?
metalhead is offline
post #11 of 22 Old 07-13-2013, 09:14 AM
pete1991YJ
Because the factory put out a dealer service bulletin in like 1992 that changed the spec. Also from experience, these trannys don't like anything over 30 weight, I know cuz I tried it. Because they are built to such close tolerances and heavier oil needs a place to squeeze out into. Also because they aren't as rigid as an iron case 4-speed. The heavier oil actually increases gear and bearing wear because the tooth load on individual gear teeth goes way up and things start to overheat with the wrong oil.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #12 of 22 Old 07-13-2013, 10:01 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Actually, I haven't heard good things at all about Synchromesh. And given that the cheapest 10w30 provides absolutely perfect shifting from 80* down to -10*F in my transmission, I don't see why spending any extra money would be worth it.
http://www.jeepforum.com/forum/f12/1...trans-1100022/
Multiple people in that one thread report issues running it.
-Matt
White '94 YJ Sport
UltimatE is offline
post #13 of 22 Old 07-13-2013, 10:08 AM
UZI4U
After pulling a valve cover off of a V8 that had been ran with Pennzoil all of it's life and finding, what could be best described as, a gelatin mold, I'll never run that crap in anything...to include my lawn mower.
MCLMM
UZI4U is offline
post #14 of 22 Old 07-13-2013, 12:24 PM
metalhead
2011 WK
From talking to people at the jeep dealership I work at they say to use the 75w90 gear oil.
post #15 of 22 Old 07-13-2013, 12:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Conventional 10w-30 is the new spec for the AX-15. I use the cheap stuff from Wal-Mart.
Here's why I use 10W-30 motor oil in my AX-15.
The Mopar gear oil part number used to be 4897622aa, but when you search that part number you'll see it has been superceded by part number 4761839AC which comes up as 10w-30 motor oil. Here's a link to search the Mopar part numbers.
Discount Mopar Parts Jeep Dodge Chrysler parts & accessories with great service
It's the "new factory spec" lubricant.
Based on that, I use 10w-30 motor oil. I buy the Wal-Mart "Super Tech" store brand oil because it's cheap, meets all the API (American Petroleum Institute) grade qualifications and I change mine often, at least every 6 to 12 months.
Here's a link to the Jeep Engineers Q&A thread here on JF where I questioned the Jeep factory engineers on this very thing.
Here's my question post....
http://www.jeepforum.com/forum/f144/...ml#post8016389
And here's their reply.
http://www.jeepforum.com/forum/f144/...ml#post8016473
Max
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
