AX5 to AX15 swap - JeepForum.com
post #1 of 6 Old 05-19-2008, 06:04 PM Thread Starter
gatorkiller
AX5 to AX15 swap
is this a direct replacement in an 1997 wrangler. 2.5 liter. looking to upgrade to ax15 transmission.
gatorkiller is offline
post #2 of 6 Old 05-19-2008, 07:52 PM
mighty4banger
To install an AX15 to replace a AX5 you will need an adapter kit or a bunch of other parts... It is not a direct bolt up... and it's not cheep.
https://eshop.advanceadapters.com/co...563-712563.htm
95 YJ 2.5L 5 speed, 4.88's, Aussie Locker D30, 35" Mud Rovers, Herculined tub, TKH rear bumper, Ford 8.8, JB Conv. SYE, Sylvania Silver Stars, T-MAX 9K winch, MORE 1" body lift, Turbo City oil pan skid, Rubicon Express 4" lift...
2012 KK Black all stock.
mighty4banger is offline
post #3 of 6 Old 05-19-2008, 07:54 PM
kloppk
Sorry - not a direct swap.
Requires special adapters to make an AX-15 mate to a 4 cyl.
Also the tcase input shaft is 21 spline and the AX-15's shaft is 23 spline. You need the correct tcase witha 23 spline input or you'd have to get your hands on a 23 spline input gear and swap it into your tcase.
kloppk is offline
post #4 of 6 Old 05-19-2008, 07:59 PM
drew2000
drew2000's Avatar
$448....ouch!
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #5 of 6 Old 05-19-2008, 10:43 PM Thread Starter
gatorkiller
i have a 350 zz4, whats the best route to swap my 4 bangers to this?
post #6 of 6 Old 05-20-2008, 01:34 AM
Blazin Den
this one is on the pirate4x4 forum.
http://www.pirate4x4.com/forum/showthread.php?t=181361
95 White YJ 2.5L/AX-5 Stock on 31s. Ground Pounder Fab (BESRK) Front Bumper, Herculined Interior, Windshield/Front Bumper Mounted Lights, Uniden PRO 520XL Cb,Hidden Hitch Trailer Hitch, Bestop Supertop, Modified CJ7 Hardtop and CJ7 Twist Handle Full Doors (winter)
Blazin Den is offline
99 Tj Ax5? Ax15? To 92 Yj Ax5 Swap??? Help Please whatmud78 YJ Wrangler Technical Forum 0 09-04-2009 12:44 PM
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 07:38 PM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 11:05 PM
ax5 swap for ax15 Hockey1 YJ Wrangler Technical Forum 2 07-10-2007 12:10 PM
ax15 swap 5.0YJ YJ Wrangler Technical Forum 5 11-30-2006 03:27 PM
