AX5 - 5th Gear Problem - Page 2 - JeepForum.com
post #16 of 23 Old 11-22-2012, 05:56 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Article on the AX15, applies to AX5 as well. http://www.jeepforum.com/forum/f12/b...change-865520/
You can skip to post #7 if you don't like reading.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #17 of 23 Old 11-22-2012, 07:46 PM Thread Starter
53flattie
10-30 it is!!!
Everything is back together, but I don't feel like fighting the Black Friday crowds to get a few quarts of oil and ATF, so the test drive will have to wait until we get back from camping this weekend.
While pouring the used ATF and oil from the drain pan to a jug, I found this little guy (in the oil). I'm assuming it came from the transmission, and it looks like a detent ball. I pulled the three detent plugs from the passenger side and all three have their springs and detent balls like they are supposed to. Any idea where else this might have came from?
53flattie is offline
post #18 of 23 Old 11-22-2012, 08:22 PM
Opihi59
Opihi59's Avatar
There is a bearing in the rear case under a gear on the cluster gear, behind 5th shift hub as I remember off the top of my head, but that's on the AX15. Did you find this in the front case half or the rear case half? Also one for the 5th gear shift detent which is separate from the 3 stacked shift detents in the side of the intermediate plate.
Opihi59 is offline
post #19 of 23 Old 11-22-2012, 08:31 PM Thread Starter
53flattie
This was in the rear half of the case.
Do you know where the detent cover is for 5th gear? Is there another on the drivers side?
post #20 of 23 Old 11-22-2012, 08:33 PM
Opihi59
Opihi59's Avatar
Unlikely that it is anything other than the 5th detent ball. It is on same side as the other detents, just further back on the rear case, same side.
Opihi59 is offline
post #21 of 23 Old 01-23-2013, 04:49 PM Thread Starter
53flattie
I meant to conclude this post earlier... Got everything back together and it all worked perfect. Thanks to all those who replied to this thread!!!
post #22 of 23 Old 01-23-2013, 05:08 PM
Mark05059
where did the ball go?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #23 of 23 Old 01-24-2013, 06:34 AM Thread Starter
53flattie
5th gear detent ball. Went right back in with no problems.
