AX5 - 5th Gear Problem - JeepForum.com
post #1 of 23 Old 11-19-2012, 05:13 PM Thread Starter
53flattie
'93 YJ, didn't have 5th gear when I bought it. I found the "AX5 5th Gear" sticky and followed it. Everything went great with disassembly - thanks so much to the author.
The problem is, my retainer isn't broken, but the gear is. I have 2 questions - can the 5th gear be pulled off the shaft without further disassembly? And if so, how in the hell do you get that split ring off? Everything spins freely, so I can't get any leverage...
53flattie is offline
post #2 of 23 Old 11-19-2012, 05:52 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Technique to remove the snap ring is 2 screwdrivers of equal length, whack on top of the screwdrivers with a large hammer. Gotta have 2 same length screwdrivers, and gotta hit them bot simultaneously. Snap ring with come off and then ricochet into a place where you will never find it again.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 23 Old 11-19-2012, 06:02 PM Thread Starter
53flattie
Thanks Opihi - I am familiar with that method and will certainly give it a try. Lol.
I considered wedging something between the gears, to keep them from spinning. But I was afraid I might break a tooth...
Will the 5th gear come off the main shaft?
post #4 of 23 Old 11-19-2012, 06:06 PM
sxi4evr
dang i bet thats a tough job to do with the trans still under the jeep
Check out my YJ!!!! http://www.jeepforum.com/forum/f22/first-timer-yj-build-1373716/
sxi4evr is offline
post #5 of 23 Old 11-19-2012, 06:34 PM
Opihi59
Opihi59's Avatar
Generally not that hard to do under the Jeep--remember the snap ring has broken off and you can then clamp on the retaining collar upgrade. Unless of course you have gears to replace but then it's only a bit annoying.
It should, what generally happens is that the ring breaks, then the gear slips back and just "spins" on the shaft. Unless the other 5th gear (countershaft) is trashed, you should be able to slip on a new mainshaft 5th gear, the retaining collar upgrade, or new snapring, and have 5th gear again. Don't even think about using that old snap ring over again.....
Opihi59 is offline
post #6 of 23 Old 11-19-2012, 08:27 PM Thread Starter
53flattie
I ordered a new snap ring and collar last week. Unfortunately, I didn't know that the gear was shot until I finished the disassembly tonight. Looks like I'll be placing another order tomorrow.
Thanks for the information.
And for anyone else thinking of tackling the job with the trans still in the Jeep - it's really not bad at all.
post #7 of 23 Old 11-19-2012, 09:38 PM
Opihi59
Opihi59's Avatar
If you can't find the parts you need, PM MeanMax and he'll tell you where to get the gears you need, from one of his sources. I see that your mainshaft 5th gear is chewed up, how about the 5th gear counter shaft that mates with it? It is also possible you could find parts close by in salvage yards, or at a tranny shop with a graveyard out back.
Somehow I thought you were from Clover? I have family in Easley and in Anderson, graduated from HS there quite a few years back, was up in Easley last August. I know my way all around there from many bike tours up into Oconee and beyond from Anderson.
Opihi59 is offline
post #8 of 23 Old 11-19-2012, 09:53 PM
ROTTEN
Just curious. Before 5th went did it feel kinda rumbly when it was in that gear. Kinda like vibrations but the faster you went it smoothed out?
I'm new
ROTTEN is offline
post #9 of 23 Old 11-20-2012, 03:58 PM Thread Starter
53flattie
Rotten - it actually didn't do anything but click when I put it in 5th gear. Now I know that it was probably the counter gear spinning against the broken main shaft gear.
post #10 of 23 Old 11-20-2012, 04:02 PM Thread Starter
53flattie
Opihi - I live within a half mile of the new Easley High School, right on Hwy 8. Very small world!
How did you get to Hawaii, from Easley, SC??
The counter gear is fine, surprisingly. Not sure why the main gear would have failed like it did. It's not like there are extreme torque loads on 5th gear...
I was able to source a new gear at my local 4x4 shop (via Omix Ada) for $86. I just wish I wouldn't have ordered that $40 retainer...
post #11 of 23 Old 11-20-2012, 04:25 PM
Opihi59
Opihi59's Avatar
I'd still go with the retainer, if we're talking about the snap ring replacement collar featured in MeanMax's writeup from the FAQ. You'll be kicking yourself if you don't do it and in a year you're back under there fixing that item. It's a good investment as AX5 is notorious for dropping that snapring. Just think how much you saved doing all this work yourself.
Opihi59 is offline
post #12 of 23 Old 11-22-2012, 04:29 PM Thread Starter
53flattie
Double screwdriver trick worked the first try. Thanks for the tip!
Now for reassembly...
post #13 of 23 Old 11-22-2012, 04:32 PM
Opihi59
Opihi59's Avatar
It looks like you're on your way to success on this.
Happy Turkey day, it's early yet here in the Sandwich Isles and we haven't eaten yet. But just think, you have an endless supply of Duke's Mayonnaise, and I have to have it mailed in.......
Opihi59 is offline
post #14 of 23 Old 11-22-2012, 05:06 PM Thread Starter
53flattie
One last thing... I've seen one reference to using 80W in the transmission, and another saying 10W30. Can you confirm which is correct?
post #15 of 23 Old 11-22-2012, 05:48 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
10w30 without a doubt.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
