Ax5 - JeepForum.com
post #1 of 9 Old 07-27-2013, 11:39 AM Thread Starter
Hilblee
Ax5
Just a quick question----My AX5 tranny jumps out of 5th when i let off the gas. Is this a problem with that snap ring missing or is my syncros shot? I read all through the posts on putting that collar on but it didnt mention my problem.
Hilblee is offline
post #2 of 9 Old 07-27-2013, 03:58 PM
lah2420
Sounds to me like the shift sleeve(I know that isn't the proper term) isn't going all the way on the gear. Synchro shouldn't keep you from that. If it was the snap ring you probably wouldn't have any 5th gear at all. I had an AX15 that was just the opposite. The sleeve wouldn't come all the way off. Ended up being a bent shift rail. IMHO it sounds like the tranny needs to be opened up, but I'm not an expert. Look up Mean Max and PM him if he doesn't respond to your post. You can trust his opinion more than mine.
lah2420 is offline
post #3 of 9 Old 07-27-2013, 04:19 PM
Rproject
1987 YJ Wrangler
Do you have any kind of lift on the Jeep? The shift rod may not be fully engaging 5th gear and only popping out when there is no "tension" on the gear.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #4 of 9 Old 07-27-2013, 05:35 PM Thread Starter
Hilblee
4 inch lift--how can you tell on the tension?
Ive owned 74, 75, 76 and 79 CJ-5s. 76 J10 (prob the best jeep ever) 89 YJ (current) and a 98 TJ. I consider all of them "Money Pits" Always throwin money at em whether they need it or not!
Hilblee is offline
post #5 of 9 Old 07-27-2013, 06:12 PM
Rproject
1987 YJ Wrangler
With a 4" lift, the shifter could be hitting the tub when you're in gear, not allowing the transmission to fully engage. Especially if you have a transfer case drop.
1996 White ZJ
Rproject is offline
post #6 of 9 Old 07-27-2013, 06:39 PM
jokerchief462
Shifter boot old and hard that is also a player
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #7 of 9 Old 07-28-2013, 01:04 PM
fishadventure
Sometimes when a tranny sees lots of highway miles and/or got run for a while with low lube the relatively small OD gear gets worn and stop holding in play. If other mentioned items check out maybe a couple new gears are in order. The popping out usually happens under power however, not let-off. A thought...
fishadventure is offline
post #8 of 9 Old 07-28-2013, 03:24 PM Thread Starter
Hilblee
Thanks guys-----just serviced it for the first time and lo and behold----by the pics of the drain plug, its a AX15 not the AX5 as I was told. Thats awesome. Must have traded it out when the previous owner had the 93 4.0 put in.
Hilblee is offline
post #9 of 9 Old 07-28-2013, 03:35 PM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Yes, a transfer case drop can keep it from engaging fully in 5th gear. As said above, it may be hitting the tub. Also, your tranny mount may be bad, causing it to it the tub and pop out of gear.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
