ax15 swap - JeepForum.com
post #1 of 6 Old 11-29-2006, 08:44 PM Thread Starter
5.0YJ
ax15 swap
i know that alot of guys with the ax15 are swapping from a internal slave to the external and its been discussed alot so maybe you guys can help me out...my buddys trans needs a rebuild in his 94 YJ....it has a external slave already but he has a transmission that is internal slave....he says the input shaft is different or something...i havent looked at it yet but what is it gonna take to get it working?? everything i found online doesnt say anything about them being different
92 YJ 5.0 AOD NP208 Full width Dana 60/44 axles RE4.5XD SOA lift kit XJ rear stretch comp cut fenders currently on 38" TSLs with hummer double beadlocks and runflats Warn 10,000lb winch Optima battery
WISH I NEVER SOLD IT
97 cHEROKEE SPORT 4DR...BONE STOCK....LOOKING FOR PARTS TO MOD IT
5.0YJ is offline
post #2 of 6 Old 11-29-2006, 09:57 PM
pyro9862
They should be the same. Count the splines, measure the shafts, make sure the trannies are the same leangth. If they are it's the same thing. I know the AX-15 bell housing and tranny are one piece though. If the bell housings are different on the external/internal it may not work.
pyro9862 is offline
post #3 of 6 Old 11-29-2006, 10:42 PM
Tshark299
Tshark299's Avatar
1987 YJ Wrangler
Check out the discussion on swapping the bearing retainer in this thread...
http://www.jeepforum.com/forum/f12/ax15-internal-external-slave-344550/
that's probably your buddy's problem. unless he's talking about the pilot bushing/bearing, which might be different between the early and later transmissions.
- 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
- Donated drive train to the YJ, Parted out the rest
- Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline
post #4 of 6 Old 11-30-2006, 09:00 AM
timatoe
timatoe's Avatar
I think your right on the bell housing being the difference, as far as mounting the slave external. Not to bust balls, but the bell housing and tranny are not one unit. When I replaced my tranny I reused the stock bell housing. I do think however the AX5 may be a one piecer, but not the 15.
timatoe is offline
post #5 of 6 Old 11-30-2006, 09:08 AM
pyro9862
You're right, I had to go downstairs and look at my AX-15. The bell housing is separate.
pyro9862 is offline
post #6 of 6 Old 11-30-2006, 02:27 PM
toomanytoys
Sorry to high jack the thread. Other than the obvious, one being internal vs. one external, are there any major advantages to converting? Mine is fine for now, just asking for future reference.
toomanytoys is offline
99 Tj Ax5? Ax15? To 92 Yj Ax5 Swap??? Help Please whatmud78 YJ Wrangler Technical Forum 0 09-04-2009 11:44 AM
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 06:38 PM
AX5 to AX15 swap gatorkiller YJ Wrangler Technical Forum 5 05-20-2008 12:34 AM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 10:05 PM
ax5 swap for ax15 Hockey1 YJ Wrangler Technical Forum 2 07-10-2007 11:10 AM
