Ax15 swap - JeepForum.com
post #1 of 6 Old 09-17-2011, 03:16 PM Thread Starter
dougbrown
Ax15 swap
Hello guys. I want to swap out my Ba-10 trany to a ax-15. The jeep has a 4.2L I6 in it. What do I need? Bell, t case ect and what will match up? Also what else will I need? While I'm doing this I want to put a new clutch in. I drive it on the road alot but also 4 wheel in the woods, Mostly mud and trail riding. No rock clumbing!
dougbrown is offline
post #2 of 6 Old 09-17-2011, 04:54 PM
lah2420
>Bell housing and tcase, or else change the tcase input shaft.
>When I did mine several years ago I also changed from an internal to an external slave cylinder. For that you will need the fork inside the bell housing and a release, or throwout, bearing.
>I bought a combination master/slave for the clutch hydraulics.
>I also bought a clutch kit for a year model that had the external slave. Sorry, I don't remember the year it changed off hand. The disk and pressure plate are the same part numbers for all the 6 cylinder YJs. The difference in the kits is whether you use an internal or external slave.
>Not sure about the transfer case shifter mounting. You may need one for mounting on an AX15. I went from an NP207 to the 231, so I needed everything.
>Transmission mount for the AX15.
>Unless you want to modify the skid plate, you might try to find a newer one of those also. I modified mine. Mainly just drilling new holes.
lah2420 is offline
post #3 of 6 Old 09-17-2011, 08:46 PM
srdart67
You will be able to use any year ax15 but but you will need to get the right bell housing for your motor. they also changed them a little in 97 they put a larger input shaft in them. If you are buying one with the larger shaft you will need to get a the 97 and up pilot bearing. They come with the clutch kit but I am not sure if the flex plate is the same bolt pattern to the flywheel as the earlier models as I only had to replace the bearing when I changed mine.
srdart67 is offline
post #4 of 6 Old 09-17-2011, 11:49 PM
yjgrillin
I just did an AX-5 to AX-15 swap, and while looking found a guy in PA on Ebay who had an BA-10 to AX-15 listed, I called him and told him what I was doing, he knew what I wanted and changed some of the parts around. I think it was 1200-1300 for the complete set up. (Rebuilt transmission and transfer case, bellhousing, etc.) I don't know much about the BA-10 but might be something to look into. The only issue I had was shipping (I'm in AZ) and it took him awhile to get everything out to me, also, he wasn't the best at communicating with me about what was going on, I had to call him a couple times to get information. (He does build them for each order, so keep that in mind as well.) Just figured I'd offer it. Search Ebay for him, I think his website is jeeptransmissions.com
I'm going to get the transmission and everything started on Tuesday, I cannot speak to the quality of his parts yet. I just wanted to add this in case I run into issues later this week. If you'd like, I can update you when all is said and done.
yjgrillin is offline
post #5 of 6 Old 09-18-2011, 12:18 AM
Fenix85182
Fenix85182's Avatar
You can get most of your parts of eBay or CraigsList for pretty inexpensive. When I swapped from an AX15 with a bad input shaft bearing to a newer one, I also chose to swap the internal slave for the external slave. While I'm not positive, I think it was '94 and up with the external slave. However, the pilot hole on the 4.2 crank is larger than that of the 4.0 that the newer slave/tranny combo is usually paired with.
For a less-expensive swap, find a tranny from an '89-'92. For an easier-to-work-on swap (external slave), '94 and later is what you want.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #6 of 6 Old 09-18-2011, 12:25 PM
lah2420
You can use the older tranny and just get a bell housing for the external slave. That's what I did.
lah2420 is offline
Doing an AX15 swap Rubidon1994 YJ Wrangler Technical Forum 6 06-11-2011 06:44 PM
late ax15 to eraly ax15 swap questions baltimorebiker YJ Wrangler Technical Forum 3 03-24-2010 05:01 PM
2.5L AX15 swap czjeeper YJ Wrangler Technical Forum 2 12-26-2008 06:38 PM
305 Swap into my YJ with ax15 jvidmar YJ Wrangler Technical Forum 2 08-28-2007 10:05 PM
ax5 swap for ax15 Hockey1 YJ Wrangler Technical Forum 2 07-10-2007 11:10 AM
