AX15 shifting problem - JeepForum.com
post #1 of 15 Old 09-08-2013, 05:23 PM Thread Starter
Swietzer94
Quick question about the Ax15 my jeep shifts fine through the gears while the engine is off, as soon as I start it up I can not shift it into any of the gears except reverse. I have to put it in reverse first to be able to get it in any gear any ideas? I need help
Swietzer94 is offline
post #2 of 15 Old 09-08-2013, 07:29 PM
zte87
GIVE IT THE ONION
zte87's Avatar
That is strange, I would start with a changing the tranny fluid out to 10-30 motor oil......bump for more ideas!
zte87 is offline
post #3 of 15 Old 09-08-2013, 07:42 PM
kloppk
Sounds like the clutch is not fully releasing or possibly a bad pilot bearing.
Does the clutch grab just off the floor?
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #4 of 15 Old 09-08-2013, 07:52 PM
Mark05059
so check the clutch master for fluid..
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #5 of 15 Old 09-08-2013, 07:55 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Hydraulic issue all the way.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #6 of 15 Old 09-08-2013, 08:10 PM Thread Starter
Swietzer94
Clutch master is full and looks brand new. This problem just started today, and I don't notice any difference in the clutch pedal. It seems to grab right where it should. I find it odd how I can easily put it into reverse every time. It will easily shift into 1st if I'm rolling slowly forward or back. But if I come to a stop sign or red light and completely stop. I can not get it back into gear without having to first put it in reverse. No grinding noises or anything like that either.
post #7 of 15 Old 09-08-2013, 08:16 PM
salsomano1a
i had expierenced this exact problem when i changed my clutch master cylinder, you need to bleed the system because it has air in it.
salsomano1a is offline
post #8 of 15 Old 09-08-2013, 08:20 PM Thread Starter
Swietzer94
I'm going to bleed it tomorrow to eliminate that. Would it make sense that it would all of a sudden be like that?
post #9 of 15 Old 09-08-2013, 08:30 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You may have a problem like this, but with different symptoms, if the failure point was in a different spot.
http://www.jeepforum.com/forum/f12/c...h-help-853773/
Max
Mean Max is offline
post #10 of 15 Old 09-08-2013, 09:49 PM Thread Starter
Swietzer94
post #11 of 15 Old 09-08-2013, 10:00 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
If your master cylinder spring failed, like in the thread I linked to but closer to either end of the spring, you might not be getting the full benefit of pushing the clutch pedal.
This would result in similar symptoms as air in the line.
The truth is, you can't be certain. Pick the low-hanging fruit first. Work in this order.
1) Bleed
2) Replace hydraulics
Max
Mean Max is offline
post #12 of 15 Old 09-09-2013, 07:09 AM Thread Starter
Swietzer94
Update. This morning after sitting all night, it is shifting a lot better, there is still a little force needed to get it into 1st but I can now put it in gear at a dead stop. I still plan to change the oil and bleed the clutch tomorrow though.
post #13 of 15 Old 09-13-2013, 07:00 PM
salsomano1a
let us know after you bleed it how it runs.
post #14 of 15 Old 09-13-2013, 10:20 PM Thread Starter
Swietzer94
Sorry about the late update, after bleeding the clutch and changing the oil I did notice it got a little better. But as soon as it warms up (especially if I'm taking her on the highway) it still is difficult to put it in gear.
post #15 of 15 Old 09-20-2013, 09:28 PM
flcracker
I am having a problem with the clutch not seeming to release fully also. We just swapped out the original tranny for one from a TJ to get teh newer tranny and external slave on it and we did do the clutch and new master slave prebled combo and it felt fine at first but after a little over a month, the pedal is soft and releases almost at the floor. If I was talking about my old one, I would think it needed to be bled but its a new set. Looking for answers??
It is hard to put into gear at a stop and you really have to pull it to get reverse....
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline
