AX15 shift tower bushing - JeepForum.com
post #1 of 21 Old 01-28-2008, 08:33 PM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
I am still accumulating parts for my AX15 rebuild. I have found that the bushing in the base of the AX15 shift tower is toast, most of it had fallen away. I have the Parts CD for jeeps, I have the FSM as well. The parts guy at the dealership was less than helpful, he told me what I needed was the bushing that is stuck on the bottom end of the shifter lever and tried to give me part number 8350-0519 wrong part. I looked through my Official parts CD and could not find my part demonstrated anywhere in there, nor can I find it shown in the FSM anywhere. To make sure I am sending the right nomenclature, what I and most everyone else refers to as the shift tower is listed as part number 5252-054 and is called "retainer, control shift lever." It is held onto the rear extension housing of the AX15 with 4 bolts. There is a gasket between this and the extension housing. The part I need is a ring type bushing that fits in the bottom of the shift tower--it is not the small nylon bushing that fits on the bottom end of the shifter lever. It is also not the boot that fits around the shifter shaft. If needed, I can take a photo of where it is supposed to fit and submit that. I could not find this part listed on quadratec, can anyone help me find the part number and/or a source for this part??
Thank you in advance for your interest and assistance.
EDIT--I came up with the answer for this question, but I never closed out this thread. If you will drop down to the last post, you'll find the answer and the pictures, and a link to another thread in the FAQ covering this question.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Last edited by Opihi59; 08-17-2012 at 01:22 AM. Reason: Closed out with the solution. Sorry I didn't do it sooner.
Opihi59 is offline
post #2 of 21 Old 01-28-2008, 08:43 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Quadratec does have them, you need to call em though, they're not in the catalog or on the web.
- Ernie
Richmond88yj is offline
post #3 of 21 Old 01-28-2008, 08:47 PM
SonofSam02
they dont make just the bushing
period
it is an integral part of the shifter housing.
I went through this last year
You have several options:
Dealership wants about $150 for a new shifter
B&M and similar shifters are about $200
what i did was go to bass pro shops and buy a rubber rollar thingy. I then gut/grinded/burned/cursed it until it fit down in there. I made it similar to the one that came out
SonofSam02 is offline
post #4 of 21 Old 01-28-2008, 08:59 PM
Richmond88yj
Eat, Sleep, Jeep
Ahhh, makes sense. When I got my shifter from quadratec they were in the the kit but packaged separately. I thought it was sold individually.
- Ernie
post #5 of 21 Old 01-28-2008, 09:42 PM Thread Starter
Opihi59
Opihi59's Avatar
Oh. My. Gawd.
I will call Quadratec tomorrow and beg for them to send me the part......having to buy the entire shift tower for the (perishable) seal is closely akin to having to purchase a new car because the tires wore out. Of course, I will post follow-up on this for the forum's collective benefit.
About 2 years ago I replaced one of these on a Toyota W56 5 speed, I suppose if it is a close match that would be a starting point to look for a substitute. Sorry for bringing up the T-word on this forum, but sometimes, you have to be innovative.
Opihi59 is offline
post #6 of 21 Old 01-28-2008, 09:46 PM
pat8942
pat8942's Avatar
I just had mine apart the other day and mine had a rubber ring at the bottom of the shift tower.
More than likely you have to buy the tower to get it.
My guess it's more of a seal than a bushing because the ball on the lever doesn't actually ride on it.
pat8942 is offline
post #7 of 21 Old 01-29-2008, 09:04 AM Thread Starter
Opihi59
Opihi59's Avatar
Well, the large knob/ball at the base of the shifter does rest on this at the bottom of the round portion of the shift tower. Then there is a small "finger" that sticks down from that about 2 inches with a smaller knob. Every parts place is trying to sell me the small bushing, rather than the bigger bushing the big knob sits in. This part rests on a shoulder at the base of the round portion of the shift tower. Otherwise the "big knob" will be pivoting against the case and shearing off metal frags which then fall down into the rear case. The spring under the retainer cap holds this portion of the shifter down against this bushing/seal. I called several online sources this morning and they all told me this part isn't available. Likely I'll take my shift tower around town to some transmission shops, and/or to Toyota to see if one of their bushings from some of their transmissions will fit, or will be adaptable to this. If anyone else comes up with any kind of source for this part, or even a part number, let me know.
Opihi59 is offline
post #8 of 21 Old 01-29-2008, 10:00 AM Thread Starter
Opihi59
Opihi59's Avatar
Just to give some early feedback--cyberjeep had an exploded diagram of an AX15, I had called them once already and called back......Item #6 on their diagram was the shift tower. When you click on the "more info" tab for that, it dosesn't describe the shift tower, but an oil seal. Ultimately we decided that the part I wanted was #4 on the diagram described as "4864226X Oil Seal - (Fits inside the Shift Retainer - No. 6)" I ordered one for $5.25 plus S and H, I suppose the part will make it to Honolulu in about 2 weeks and if it is the right part, I'll post a follow up for the forum's benefit with photographs, etc. Fingers crossed, etc.
Opihi59 is offline
post #9 of 21 Old 01-29-2008, 10:04 AM
SonofSam02
that would be sweet
i looked all over for about a week and couldnt find one
post #10 of 21 Old 01-29-2008, 10:40 AM
knipdm01
check out rsgear.com great support and many oem parts with the mopar sticker on them!
knipdm01 is offline
post #11 of 21 Old 01-29-2008, 02:34 PM
pat8942
pat8942's Avatar
I was searching and found the part you need for $12.95
http://www.thejeep.com/aisin.html
pat8942 is offline
post #12 of 21 Old 01-29-2008, 02:35 PM
merlin7782
merlin7782's Avatar
CAll MAN-TRANS, they have the part... 1-877-626-8726
merlin7782 is offline
post #13 of 21 Old 01-29-2008, 03:43 PM
pat8942
pat8942's Avatar
If you Google 4864226X you will find lots of sources.
pat8942 is offline
post #14 of 21 Old 01-29-2008, 04:33 PM
ctm
are you sure it's not 83500519
ctm is offline
post #15 of 21 Old 01-29-2008, 05:28 PM
pat8942
pat8942's Avatar
That number is for the complete tower/retainer and its high dollar.
pat8942 is offline
AX15 shift tower bushing Opihi59 YJ Wrangler Technical Forum 27 01-15-2016 11:13 AM
Filling AX-5 through shift tower? superslayer TJ Wrangler Technical Forum 1 02-21-2009 10:09 AM
AX15 Pilot Bearing or Bushing?? ID89YJ YJ Wrangler Technical Forum 0 12-31-2006 07:43 AM
Shift tower problem YJfrom94 YJ Wrangler Technical Forum 2 07-21-2005 12:43 PM
HELP!!! Shift Tower Trouble topfuel83 TJ Wrangler Technical Forum 2 05-07-2005 07:41 PM
