AX15 shift stick removal - JeepForum.com
post #1 of 12 Old 07-01-2007, 04:27 PM Thread Starter
kimvansa
Anyone have any tips on how to remove the shift stick (gear change stick) from an AX15 without taking the whole assembly out of the top of the transmission. I know they push on to a square end section similar to the 4WD stick but I can't make this move at all. I need to swap this stick out for another I have as the knob bust off!!
_____________________
1992 4.0L 5 speed manual
kimvansa is offline
post #2 of 12 Old 07-01-2007, 04:42 PM
$300WRANGLER
Easiest just to remove the 4 bolts and take the whole thing out at least it was for me.
Scott
1993 Red Jeep Wrangler 4.0L HO 200K Miles runs strong AX-15 Tranny WAS BROKE NOW FIXED Perfect body/interior JUST WRONG COLOR
For 300 bucks couldn't go wrong!! First Project : Tranny
Second Project: Let the modding begin
$300WRANGLER is offline
post #3 of 12 Old 07-01-2007, 04:50 PM
cosminciortan
cosminciortan's Avatar
1- replace just the knob. cut, grind, rethred as required
2- to take out the stick:
-remove rubber boot and dust boot to give yourself acces to the top of the tranny.
-you will now see a smaller rubber cap where the stick meets the ax15. pull this up and out of the way.
- this is where it gets tricky: using two fingers, push down as hard as you can on the small metal plate (~2"diam) surrounding the stick. it should go down about 1/2-1". continue to push as you twist your fingers to the left, as to rotate the retainer plate.
- this will unlock the retainer and it should pop up when you release
- the stick is now unlocked and should be pulled out with little effort
- the whole thing can be done from under the car as well (you'll need plenty of room -> elevator, ramp or pit)
if i can do it, you can do it
'95 2.5l red YJ. 35"BFG MTs on 4.5"SKYJACKER lift+ 5/8"Boomerangs, overhauled AX5 (still sucks)
smittybilt flares, bestop softtop and doors, double core aluminum radiator with Flexalite fan, new brakes allround, all poly bushings, armour
cosminciortan is offline
post #4 of 12 Old 03-29-2010, 08:21 PM
Danimal713
removing the shifter shaft from the transmission is what was given for an answer but not what he was asking. The shaft is in 2 pieces and the square part he mentioned is at the joint. I too am trying to figure out how to get the top shaft off the bottom part that fits into the AX-15 top. The knob snapped off with the threads even using PB Blaster. I have a new complete shaft but the bottom part on original is in better shape so I want to use it instead with the top shaft. Does anyone know how to get the 2 pieces of the sshaft apart?
Danimal713 is offline
post #5 of 12 Old 03-29-2010, 08:30 PM
Burnerman
Burnerman's Avatar
I don't think you can remove the top part from the bottom. It's bonded rubber. The metal retainer just pushes down and turns 1/8 of a turn and the shifter is out. If it's rusted then that's all the more reason to get it out and clen it out. The one in my son's 93 and my 92 came right out. push down and use a bit of grit cloth under your thumbs to get traction on the smooth steel to turn it.
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 12 Old 03-30-2010, 06:29 PM
Danimal713
The bottom part that twists into the top of the xmission goes in & comes out fine. The shaft is in 2 sections & I need to get them apart to remove the rubber inner boot and also replace the top part of the shaft because the threads twisted off inside the knob. The top of the bottom part of the shaft is the square chunk of metal mentioned in the original post. It looks press fit into the bottom of the top part of the shaft. Anyone have any idea how to get it out?
post #7 of 12 Old 03-30-2010, 06:59 PM
Mark05059
ok I think I found what your looking for.
http://www.jeepforum.com/forum/f12/s...hifter-513891/
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 12 Old 07-24-2013, 05:15 PM
tonyindawoods
lift the small rubber boot up ..push down on top of shifter and turn left..that gets your stick out...to seperate the stick you need to put 2 pieces of thin metal in that sqare piece {2 little balls hold it on }or put it in a vise grab one side with visegrip and give it a shot
tonyindawoods is offline
post #9 of 12 Old 05-14-2015, 03:50 AM
jpappasll
Torch the rubber and get some gasket maker. Use fingers of a rubber glove to cover bottom and secure arm till gasket maker sets.
jpappasll is offline
post #10 of 12 Old 05-14-2015, 06:13 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
The only reason there is that big square connector is so the AX-15 can have different top parts when used on a lot of vehicles with different interiors and different trans fore/aft locations. All the aftermarket shifters out there are one piece. You could even just weld them back together later if needed.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #11 of 12 Old 05-14-2015, 08:09 PM
Opihi59
from here it gets rough
Opihi59's Avatar
The KNOB REMOVAL writeup coulda come in handy as well at the start of all this. Amazing all the stuff that is hidden away in the FAQ page.
Seriously though, it is easier to do if you remove the shifter assembly from the Jeep. Better access and visibility. Press down on the spring loaded ring in the top of the shift tower immed below the black grommet, turn it counterclockwise as viewed from above, and lift it out. Put it in a vise as shown, use a pickle fork, etc.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #12 of 12 Old 05-16-2015, 05:19 PM
fishadventure
Originally Posted by Opihi59
The KNOB REMOVAL writeup coulda come in handy as well at the start of all this. Amazing all the stuff that is hidden away in the FAQ page. Seriously though, it is easier to do if you remove the shifter assembly from the Jeep. Better access and visibility. Press down on the spring loaded ring in the top of the shift tower immed below the black grommet, turn it counterclockwise as viewed from above, and lift it out. Put it in a vise as shown, use a pickle fork, etc.
I personally would not want mine removed. Nor do I want any other of the sadistic stuff you mentioned. >snicker<
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
AX15 shifter stick position? +Crusader+ YJ Wrangler Technical Forum 5 01-27-2009 07:57 PM
Stick Shift... Tompatt YJ Wrangler Technical Forum 6 01-24-2009 04:48 PM
AX15 Gear Shift Removal Shrek TJ Wrangler Technical Forum 13 09-13-2008 09:01 PM
Rattling stick shift cliffmelanie1 JK Wrangler Technical Forum 9 10-04-2007 10:27 PM
Stick Shift Knobs Jerry All-Bran TJ Wrangler Technical Forum 9 01-03-2005 12:01 PM
