#1 | |
Ax15 Rebuild
I have just pulled my tranny and the local shop want 600+ to just take it apart and diagnose the problem. I was wondering if any of you guys have rebuilt a AX15 and if you did do you have pics/ step by step breakdown. or any links would be appriciated. Thanks
1998 4dr XJ |
#2 |
Here ya go.
I bought the bearings and synchros. Removed the cluster from the case. Took the cluster and parts along with this manual to a guy I know that builds gear boxes. He installed the bearings and synchroes for $100, I put it all back together. The results were great and for ~ $250 I cant grumble. http://www.billhughes.com/temp/AX15.pdf Good Luck, Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#3 | |
~ Brian '08 Jeep WK - Overland - Ya... it's got a hemi! '96 Bronco 5.8 - Work in progress. |
#4 |
from here it gets rough
This could come in handy. http://www.billhughes.com/temp/AX15.pdf
I had access to an auto hobby shop with hydraulic press and bearing separators. You'll need them to do this job. I got rebuild kit off ebay, approx $170 with seals, bearings and synchros. You'll need many ziplok bags and notes as well. It is a satisfying job to do.
....I'm not smart, but I can lift heavy things....... Fill out your PROFILE, and don't forget to look in the FAQ for writeups I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm My Boy Scout Troop site: http://t-304.blogspot.com/ Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
