AX15 to NV3550 Swap in a YJ - Compilation of Information - JeepForum.com
post #1 of 20 Old 07-27-2012, 06:33 PM Thread Starter
nathanninja
I just finished up an AX15 to NV3550 swap in my 91 YJ, and I was frustrated with the lack of information. It took SO much research to put it all together, and then trial and error on top of that. So I decided to put together a compilation of the information that I came upon, hopefully to help someone out in the future. This is based off of personal experience, and research I've done. I may make mistakes, or have gotten false information, so please correct me if I'm wrong, the last thing I want is to lead someone astray!
First, the only write ups for this swap I could find
http://www.jeepforum.com/forum/f37/n...part-i-147709/
http://www.jeepaholics.com/support/Topic656999.aspx
http://www.jeepforum.com/forum/f12/n...stall-1379611/
http://www.jeepforum.com/forum/f12/b...nv3550-316455/
Some clutch write ups
http://www.dailydriventj.com/forum/viewtopic.php?t=811
http://www.jeepforum.com/forum/f12/c...tures-1371245/
NV3550 service manual
http://www.scribd.com/doc/23066710/M...MISSION-NV3550
Info on both trannys and some swap info (Found this after the fact, would've been useful at the time)
http://www.advanceadapters.com/pdf/nv_ebook.pdf
Here we have some basic information on both transmissions
AX15
https://www.novak-adapt.com/knowledge/ax15.htm
NV3550
https://www.novak-adapt.com/knowledge/nv3550.htm
If you read through those last two, you'll see that the NV3550 is very similar to the AX15. As far as strength goes, its the same or slightly better. It was used from 2000-2004 in TJs and XJs, and some Dodge pickups.
From, that you can see that it would have the same output that the AX15s have (23 spline) to fit the standard NP231. The input shaft is 0.75" at the tip, and 10 splines at 1-1/8" on the splined part of the input shaft. The length and bellhousing are all the same to bolt up to the 4.0 on YJs and TJs. Seems like a great and easy swap right? And don't get me wrong, it is, but there's a lot more than you see on the surface. First off lets talk AX15 differences.
Chrysler started replacing the crappy Peugot BA transmission that were in the 4.2s in 89 with the AX15. The AX15 was the same until 1992 (used in 4.2 and 4.0s), where they changed the diameter of the tip of the input shaft from 0.6" to 0.75". Which means they also had to change the pilot bearing size. It also appears that the bore for the pilot bearing (where the pilot bearing sits on the end of the crankshaft) was changed slightly, but I was never able to confirm that.
Also, in 1993 or 1994 they changed from the internal clutch slave cylinder to the external clutch slave cylinder system. The external is a more desirable model, but requires a different bellhousing, throwout bearing and shift fork. It's also worth noting here that some aftermarket external systems are sold as a SEALED unit. Meaning there is no normal way to bleed it. I say "normal way" because there are still unorthodox methods that I will describe later.
So the main differences of the AX15s that we're looking at here are the input shaft sizes and the internal vs external slave cylinder setups. Here's some reference threads for more info.
AX15 differences:
http://www.pirate4x4.com/forum/showt...bearing+clutch
Internal to external slave swap:
http://www.jeepforum.com/forum/f12/a...ite-up-592098/
Peugot to AX15 swap:
http://www.jeepforum.com/forum/f19/y...ite-up-312203/
Alright, now that that's out of the way, you should have a better understanding of what's going on in the next few paragraphs.
I'm going to make a list of all of the problems that I ran into. I may start to sound like a negative nancy, but I just want you to be fully aware of everything you'll be encountering.
Problems with the swap:
1. T-case shifter bracket
The transfer case shifters on the TJ, XJ and the YJ are totally different, so the mounting points on a NV3550 do not match the points on the AX15. You will not be able to just swap your AX15 bracket over. You will have to either mod it, or buy a conversion one.
SOLUTION:
Advance adapters makes an adapter bracket
http://www.advanceadapters.com/produ...ransfer-cases/
Or you can mod your own, as described in this thread (unfortunately his pictures don't work)
2. Transfer case clocking (NOTE: only applicable if your NV3550 is from an XJ)
In the cherokees, the holes on the output of the NV3550 are clocked (rotated, drilled) to the left of the the holes on the wrangler transmissions. The result is that the oblong section of the transfer case that sticks to the left, hangs down about 1.85" lower than normal. This WILL result in your transfer case resting on the lip of your skid plate. Having a transfer case drop will not affect this at all, it's all in the clocking and the height of the transmission mount.
SOLUTIONS:
A. Reclock the transmission. Drill the holes 10 degrees to the right and it'll rotate everything up to it's normal position. There's plenty of room for it. I decided not to do this because I was afraid if I didn't get the holes just right I'd be putting stress on the seals and bearings, making it more fail-prone. Also it's a royal pain.
B. Notch your skid plate. It's just one part of the lip, and it only needs to go down about an inch. So you could cut it out, or bend it down. Not pretty, but functional.
C. MAYBE. This is just a thought. You could raise the height of your transmission mount an inch. Keep in mind, it would bring the engine angle up a hair, and the pinion angle up a hair. I haven't tried it, I don't know if its a good idea or if it'd even work.
3. Reverse light switch
The YJ's reverse light switch (or at least mine) is wired directly into the harness, no plug involved. The NV3550's is a plug. Obviously that creates a small problem.
SOLUTION:
Take the reverse switch from the NV3550, and splice the pigtail into your wiring harness. It's two wires, super simple.
4. Pilot Bearing
This one is what made my swap take 5 days instead of 2. Remember how I said the older AX15s had smaller input shafts (and thus smaller pilot bearings), and how the newer 4.0s had difference bores for the pilot bearings? Well this poses a problem. If you're switching a NV3550 into one of the 4.0s with the larger bore (92+ I believe) then you'll be fine. BUT, if you're swapping into an older 4.0, or a 4.2, you're going to need something with the ID of the larger shaft, and the OD of the older bore size. I think the older bore size is 1.055".
SOLUTIONS:
A. Novak adapters makes a bushing, cheap, confirmed working by several people. I chose not to use it because I didn't want to wait for shipping. Also, slightly unnerving is the fact that on their site they don't differentiate between the different year 4.0s and the 4.2s (the different pilot bore sizes), and I thought that the bore sizes were different, so they should have a different pilot bushing/bearing for the 2 different bores. But they don't. The only thing I can think is that because its a soft bronze bushing, maybe the difference is very small and the bushing just adjusts when you tap it in.
https://www.novak-adapt.com/catalog/..._to_nv3550.htm
B. This is what I did, found a part number on someone's write up. Supposably had the ID of the new trans, and the OD of my old crank. Tested it on the trans before tapping it in, fit perfectly. Was a real tight fit into the bore, and when I went to put the trans in, I couldn't get the input shaft to seat in the pilot bushing. After 4 hours of struggle I ended up taking it back off and measuring the ID with calipers. Turns out, somehow between the tapping it in, or the soaking it in motor oil, it swelled, leaving the ID at 0.69 inches. SO I had to carefully sand it down to fit.
Dorman # 14674
National # PB77HD
C. Get a custom bushing. I could've gotten a bushing with a 0.75" ID and a 1.25" OD, and then had it machined to fit. But it would've been over $50 total, so I opted out.
5. Transmission shifter positioning
The NV3550s shifter knob is positioned about an inch rearwards of the YJ one. It’ll JUST barely fit with the transmission tunnel cover screwed on over top. I haven’t actually put on the rubber boot stuff yet so I can’t comment on that. Also, I’m not sure if it’s because it was an XJ knob, or because all NV3550 shifters are like this, but its bent wrong for a YJ. I’ll get some pictures up here to show it, but depending how car forwards your console is, it might contact the console in 2nd, 4th, and reverse. It’s also just awkward positioning for shifting.
SOLUTION:
A. Buy a TJ shifter. I think that might fix the angling. Obviously that only works if you’re going from an XJ trans.
B. Buy an aftermarket shifter. B & M, Hurst. They’re freaking expensive though
C. Cut and chop yours, and weld the two back together. That’s probably what I’m going to do. No way I’m spending $200 on a shifter. Freaking TJ stuff.
6. Exhaust front pipe
This may be a me only problem, but my front pipe is pressed up super tight against the transmission. It’s also bashed and bent right there from the PO, so that’s probably the real issue. I’m probably just going to get a custom bent pipe when I have the money so that I can run it in front of the oil pan.
That’s about it as far as problems go. Here is some random information and confirmations that I ran across or learned
Transmission mount
The AX15 transmission mount and bracket will bolt right onto the NV3550, as well as fit right into the mounting holes on the skid plate. So you don’t have to worry about any of that.
Tailhousing removal
When I first got my NV3550, I was actually told it was an AX15. Being a newb I didn’t see the differences, so as I’m trying to get the tailhousing off to swap it with mine, I realized things were different and that it was an NV3550, but by the time I got that far I already had it half apart, so I figured I would take a peek inside. The one part that took me forever to figure out was that the tailhousing doesn’t come off. It’s the front housing that comes away from the rear first.
NV3550 bellhousing
It will fit perfectly onto the 4.0, don’t work about that.
Slave and master cylinders
The XJ master cylinder will NOT fit on your YJ. I spent an hour modding the mounting bracket on mine only to realize it was too big to fit behind my brake booster. So what I did instead was go to a local hydraulics shop that’s hooked me up with brake lines before, and got them to splice my old master to my new slave. It took a lot of tightening, but only cost $2.30 for a fitting, and it works great now
Bleeding the slave and master
If the master beats the slave, he’s going to bleed. I don’t even know where I was going with that. Remember before how I said they sometimes sold after market units that were pre bled? Turns out mine was one of those. Apparently on the non-pre bled systems, there’s a little bleeder screw with an allen head on top of the slave cylinder. Mine had no screw, just a plastic plug. So I went the unorthodox way. I filled the system with fluid, and then pumped the slave over and over and over until the air stopped coming out, adding fluid as I went. It took a lot of pumping, but it’s smooth with no air now. A lot cheaper than buying a new system.
TJs…
TJ parts cost a lot. Used TJ shifters on ebay, $150+, are you freaking kidding me? And then you go on the TJ forum, and they’re all like “oh just get a B&M shifter” as if dropping $200 on a SHIFTER OF ALL THINGS is nothing to them. They can take their expensive bolt on mods somewhere else, I like my YJ better.
Clutch fork retainer spring
This was a tough part number to find. It's the little clip that holds the far end of the clutch fork onto the stub shaft that's bolted in the bellhousing. Dealer only part, but it should be like $3
4338855
Also,
http://www.jeep4x4center.com/spring-...k-4338855.html
http://www.quadratec.com/products/52012_03.htm
http://www.moparsupercenter.com/4338...ease-fork.html
I'm sure that I'll have a lot more to add to this, but that's all for now. Apparently something under my Jeep is leaking, so I'm off to look into that. Let me know if any of this is known to be wrong. Hope this can help someone in the future!
nathanninja is offline
post #2 of 20 Old 07-27-2012, 07:26 PM
GunHo198
Nice write up!
I'm gonna stick with my AX 15 as long as I can. LOL
Even if they grind going into reverse....
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline
post #3 of 20 Old 07-27-2012, 08:40 PM Thread Starter
nathanninja
Originally Posted by GunHo198 View Post
Nice write up!
Hahaha mine ground in reverse, whirred in reverse, no synchros on 1st and 2nd so had to double clutch going down, and then 2nd was starting to not go in on the way up. And it was making lots of noise. Got a good deal on this trans, only 80k on it, gears were pristine. Came with everything I needed (almost) plus extra parts.
The difference is night and day though. Holy crap. It's like shifting through butter, instead of shifting through gravel. I could feel the gear teeth grind together and mesh in the old one. The NV is smooth and soft. AND I HAVE SYNCHROS AGAIN!!!
post #4 of 20 Old 07-27-2012, 08:55 PM
GunHo198
Yea. I gotta shift my like an old man. Slow and easy saves the trans. No speed shifting here. Every trans I had ground in reverse. And shifting the trans seems even harder during the cold weather.
I'd have swapped for an auto but there is just too much water down here in the rainy season. Seems everyday during the summer is z river crossing. I've had people turn there Jeeps off on trail rides and towed there vehicles across deep water. Checked there fluid when it was back on dry land and it was nice and clean. Saved them a grand!
GunHo198 is offline
post #5 of 20 Old 07-27-2012, 09:02 PM
pete1991YJ
Nice write-up! Anything that keeps me reading for a couple hrs like that is a good one! I love it when people take the time to gather all the links and stuff into one spot!
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #6 of 20 Old 07-28-2012, 09:31 AM
Burlbook48
Trial By Trail
Burlbook48's Avatar
Kudos for what looks like a LOT of time and effort collecting and organizing all that in formation. Well written, clear and concise, and it doesn't read like a boring service manual.
Well done! If I ever need to swap transmissions, your post will be great resource.
You have to start somewhere to get to the middle of nowhere.
2015 YJ Of The Year
Thanks, but my rig is just a Prince among Kings. You folks gave me the answers to build it!
Burlbook48 is offline
post #7 of 20 Old 07-28-2012, 10:30 AM
jerresredyj
Hey!!!! one of the swap links was mine Due to lifes little obstackles my swap has slowed to a crawl. The one thing I can add is that I found the fork clip at Quadratec for 4.98 shipped, mine was broken. http://www.quadratec.com/products/52012_03.htm
jerresredyj is offline
post #8 of 20 Old 07-28-2012, 10:34 AM Thread Starter
nathanninja
I had to get mine done haha its my DD and I needed to get to work. Finished iat 1am the day before work. Yeah I had remembered seeing it a few other places online. Just added a few links revising that information. Thanks for all the feedback!
post #9 of 20 Old 07-28-2012, 01:12 PM
hdfxrs91
1987 YJ Wrangler
I may never swap an NV3550 in my Jeep but I give you kudos for this write-up. There is nothing like real life experience that a tech manual can duplicate. Great job!
hdfxrs91 is offline
post #10 of 20 Old 08-21-2012, 10:57 PM
Mark455SD
1961 CJ5
I just ordered an nv3550 for my jeep thinking it was basically a direct bolt in....now im panicking. I'll be reading this thanks
1986 Chevy S-10 Blazer
1974 Trans am
1997 BMW Z3
2004 Jeep Rubicon
Mark455SD is offline
post #11 of 20 Old 08-23-2012, 11:40 PM Thread Starter
nathanninja
It's not too bad. Especially if you have a wrangler NV3550 instead of the cherokee like me.
post #12 of 20 Old 08-24-2012, 09:21 PM
Mark455SD
1961 CJ5
Just got my transmission today. How can I tell which one I have?
1974 Trans am
1997 BMW Z3
2004 Jeep Rubicon
post #13 of 20 Old 08-24-2012, 11:22 PM Thread Starter
nathanninja
Look at the output flange where the transfer case bolts on. The holes should be on almost tabs, about an inch wide. If they are on the right (clockwise) side of the tabs, its a wrangler. On the left, cherokee. Having them on the left rotates the transfer case counter clockwise 10 degrees
post #14 of 20 Old 08-25-2012, 06:23 PM
Mark455SD
1961 CJ5
Hey Nathan, do you have any pics of the shifter and how it sits. I see another guy on here doing the swap and he cut the floor and made a new cover..im hoping I dont have to cut the floor. Oh and thank you for putting this write up together.
1974 Trans am
1997 BMW Z3
2004 Jeep Rubicon
post #15 of 20 Old 08-26-2012, 10:19 AM
jerresredyj
Not sure if I'm the other guy but I had no choice. The PO had already cut the floor to clear the shifter after installing tcase drop and 3" body lift, both now gone. The original cover was cut up too and didn't cover the tunnel hole before I did the swap. Making the cover is not that bad.
ax15 to nv3550 swap questions 2k2wranglerx TJ Wrangler Technical Forum 1 09-19-2011 08:18 PM
AX15 to NV3550 Swap OkLaHoMaTJ TJ Wrangler Technical Forum 1 07-08-2010 08:08 PM
Did the AX15 to the NV3550 tranny swap Wis4playcpl TJ Wrangler Technical Forum 0 08-22-2008 09:05 PM
ANYONE WHO HAS DONE A AX15 to NV3550 SWAP VABYJ YJ Wrangler Technical Forum 7 10-22-2007 09:54 AM
ANYONE WHO HAS DONE A AX15 to NV3550 SWAP HELP PLEASE VABYJ YJ Wrangler Technical Forum 8 09-05-2007 07:36 PM
