AX15 to NV3550 swap Qs - JeepForum.com
post #1 of 3 Old 09-18-2012, 09:05 PM Thread Starter
stratostix
My AX15 is just about done. I located a NV3550 freshly rebuilt at a good price. I understand its just about a direct bolt on/swap. Couple Questions tho. Can i re-use my clutch, pressure plate, pilot bearing and Throw out bearing from the AX 15? I just put in a new kit about 1200 miles ago. Also, can i re-use my AX15 shifter? Can I also re-use my np231j? (I'm 99% sure that I can but want to make sure). Thanks.
1994 YJ
1965 Mustang Coupe Hi-po
2003 BMW 325i
If they're gonna bend you over for that much, I'd definitely pay extra for the lube!!
Jeep Build thread:
stratostix is offline
post #2 of 3 Old 09-18-2012, 09:35 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Yes to clutch/PP/TO bearing. Likely your pilot will be fine as well, so long as you have the 0.750" input snout on your AX15 and that matches your NV3550 (it should). Unlikely you will need to remove your clutch assembly, and you should be able to just yank out your AX 15 and directly bolt in the NV3550.
I don't know about your shifter, at all. I do know there are 2 versions to the 3550 shifter, but they both go on the same shifter stub.
The bellhousing for the AX15 will directly bolt to the NV3550. Take a few moments to express thanks that you have the external slave so you don't have to mess with that at all. Yes, it would still bolt up even if you had a pre-94 version internal slave.
Yes, your NP231 bolts to the NV3550. As I seem to recall back in the wastelands of my cortex there may be an issue in bolting up the T case shifter though. Someone sober will need to post up a solution to that issue.
Are you SURE your AX15 is fixing to take a dirtnap? http://www.jeepforum.com/forum/f12/a...stion-1418288/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 3 Old 09-18-2012, 10:16 PM Thread Starter
stratostix
Yes, I'm positive. After going over the Jeep extensively today with a buddy of mine, listening to all sounds and testing everything out, it all came down to the transmission. I realized that I dont only get bearing noises in 5th. 5th was just louder than other gears.
As for the T-case shifter, I do have to get an adapter. Cost about $40. That's fine.
1994 YJ
2003 BMW 325i
Jeep Build thread:
ax15 to nv3550 swap questions 2k2wranglerx TJ Wrangler Technical Forum 1 09-19-2011 07:18 PM
AX15 to NV3550 Swap OkLaHoMaTJ TJ Wrangler Technical Forum 1 07-08-2010 07:08 PM
Did the AX15 to the NV3550 tranny swap Wis4playcpl TJ Wrangler Technical Forum 0 08-22-2008 08:05 PM
ANYONE WHO HAS DONE A AX15 to NV3550 SWAP VABYJ YJ Wrangler Technical Forum 7 10-22-2007 08:54 AM
ANYONE WHO HAS DONE A AX15 to NV3550 SWAP HELP PLEASE VABYJ YJ Wrangler Technical Forum 8 09-05-2007 06:36 PM
