AX15 grinding or chattering in neutral hard shift - Page 3 - JeepForum.com
post #31 of 103 Old 09-22-2008, 10:50 AM Thread Starter
xwildman138x
xwildman138x's Avatar
1995 XJ Cherokee
Yeah thats true. When it was all together the input shaft was sloppy thats why I thought maybe that pilot bearing. The orange coating on the input shafts main bearing was all peeling away and it was rusty Hopefully tonight I will get to work on it some more. Oh and I have a box of labels for every single part, I don't want to play the guessing game
"Yo ho yo ho a pirate's life for me"
xwildman138x is offline
post #32 of 103 Old 09-22-2008, 06:02 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Well I got as far as removing the fifth gear shift rail and that was it for tonight. That shift rail would not come out. The lock ball is out theres nothing in the hole the bolt is out of the shift fork and there seems to be something holding it up in the intermediate plate. It almost seems like maybe a small shaving of the aluminum is peeled out and catching in the shift fork rail groove. I gave it a little tap with the rubber mallet but no luck. I can spin it back and forth just won't slide out. It even moves back and forth (in and out) about a 1/4 inch but no further. Did you have this problem on yours when you removed the rails? I'm wondering if I'm going to have to force it past that burr. Once its out I can fix the burr but right now I can't even see it. What do you think?
post #33 of 103 Old 09-22-2008, 08:15 PM
twomanyjeeps
I remember having this problem too, only about a month ago, you do have to give it a good wind up hit, a little love tap isnt going to do it. I just got done rebuilding mine, if you need any advise let me know. Good luck with your rebuild.
twomanyjeeps is offline
post #34 of 103 Old 09-22-2008, 09:10 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Ok awesome I don't mind wailing on it but I was at that point where I was thinking "don't start hammering on it there might be a reason" Thanks man I'll be back at it tomorrow. I'm possitive I'll have more questions, thanks again!
post #35 of 103 Old 09-22-2008, 11:23 PM
Opihi59
from here it gets rough
Opihi59's Avatar
I don't specifically remember that being a problem, just make sure that the other rails are in the neutral position as an interlock pin can be pushed into a groove in the 5th gear shift rail that you won't be able to see. Shift the other rails into neutral position, it should slide out. I am not inclined to recommend a hammer at this point. If possible remove the other rails or at least the next/adjacent one to make sure it isn't an interloc pin between the shafts within the intermediate plate that is the hold up.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #36 of 103 Old 09-23-2008, 10:24 AM
twomanyjeeps
Very true, make sure everything is in nuetral. When I hit mine it wasnt a serious bashing, I came at the rail from the front to push it out torwards the rear, one good hit really about half a wind up with a 3lb dead blow hammer and the shaft practically came flying out the other end so be ready for that!
post #37 of 103 Old 09-23-2008, 10:38 AM
twomanyjeeps
Also, I think there was only three interlock balls involved with the 5th shift rail. One is taken out through the intermidediate plate cover, the 2nd is in the plate underneath the rail and the third is in the reverse shift arm that the rail feeds through. Be sure your ready for the second and third ones to pop out otherwise they're sure to roll into the hardest corner in the workshop to get to.
post #38 of 103 Old 09-23-2008, 03:23 PM Thread Starter
xwildman138x
1995 XJ Cherokee
I removed three torx caps then springs and balls. they were in a row on the intermediate plate. I looked all over but maybe I am missing something thats not on the teardown sheet
post #39 of 103 Old 09-24-2008, 12:39 AM
Opihi59
Opihi59's Avatar
Those are the detent balls and detent springs that you removed.
There is a series of interlock balls and pins between the rails, within the intermediate plate. The purpose of these are to prevent engaging more than one gear at a time. When ONE gear is engaged, the shift shaft for that gear pushes the interlock pin into the other shift shafts and prevents them from moving--movement would engage another gear and that would be disaster for your gearbox. Make sure all the gears are in the neutral position, this would also include the shift shafts in the neutral position as well if you have disengaged the shift forks from the shafts. The mechanism is very simple, but quite clever. Pages 21-45 and 46 have some figures which show the interlock pins, also you will note the notches cut into the shift shafts in the drawings, one shaft out of position will push an interlock pin into one of the notches on the adjacent shift shafts and prevent them from moving in or out.
Don't give up. You can do this. I did it and I'm not smart (but you already know the rest)
Opihi59 is offline
post #40 of 103 Old 09-24-2008, 08:37 AM
twomanyjeeps
No you have me a little worried. when I did mine, I only removed the 5th shift rail from the plate and left the all the other ones in, I didn't want to worry about them. However, when I was cleaning up the workshop I found a small pin behind the bench. I wanst even sure if it was from the tranny, when I put the 5th rail back in I only put the two interlock balls in that the manual talked about number 11 on page 21-60. I didn't see a spot for a pin, just the spot in the plate and in the reverse shift head assembly.
post #41 of 103 Old 09-24-2008, 09:14 PM Thread Starter
xwildman138x
1995 XJ Cherokee
I only have up to page 34 on that link you showed me. I tried to find it on the net on my own but didn't have any luck. I didn't see anything about those interlocks on the pages I had.
post #42 of 103 Old 09-24-2008, 11:02 PM
Opihi59
Opihi59's Avatar
It's a pretty long manual, I'll try to send it again. You can't expect to get by without it. If my link isn't good, go to this: http://www.billhughes.com/interest.htm and scan down thru it until you find the Jeep/AX15 pdf. Here is the link to the AX15 again: http://www.billhughes.com/temp/AX15.pdf If it isn't coming thru complete, go to the billhughes site...
Opihi59 is offline
post #43 of 103 Old 09-25-2008, 09:38 AM Thread Starter
xwildman138x
1995 XJ Cherokee
Awesome thanks man thats what I was looking for the site. thanks again!!!
post #44 of 103 Old 09-25-2008, 04:59 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Wow I finally figured it out. I had to shift the reverse rail and it slid right out. I stood there telling myself "your a idiot" why didn't I try shifting it before. I totally didn't even think about shifting the gears, but I was thinking about how you said it was designed and I thought well if this rail moves so the opening is in the intermediate plate then that gives a place for the ball to go when I move the fifth rail. Oh well first time is gonna take the longest, now I know why. Let you guys know when I get a little further into it.
post #45 of 103 Old 09-25-2008, 11:40 PM
Opihi59
Opihi59's Avatar
That was the part about getting the gears all into "neutral." Glad you didn't use a 3# persuader or you'd be looking for a new intermediate plate. Now just remember to collect all the interlock pins and balls as they drop out (before they drop out) They hide inside the shift rails, and in the intermediate place and walk away when you turn your back. I had to make one I lost from the end of a drill bit.....
Opihi59 is offline
Gear shift hard to move in neutral when hot spshultz YJ Wrangler Technical Forum 15 02-03-2013 12:02 AM
1990 YJ Auto, hard to shift into neutral or park from drive Nokinja YJ Wrangler Technical Forum 1 08-15-2009 09:30 PM
Tranny grinding, hard shift unideluxe YJ Wrangler Technical Forum 3 12-31-2008 08:11 PM
1993 YJ hard to shift, grinding gears etc...help 1993jeep YJ Wrangler Technical Forum 16 12-02-2006 09:58 PM
AX15 5speed stuck in neutral Help Wingryder YJ Wrangler Technical Forum 5 07-02-2002 10:41 AM
