AX15 grinding or chattering in neutral hard shift - Page 2 - JeepForum.com
post #16 of 103 Old 08-21-2008, 05:48 AM Thread Starter
xwildman138x
xwildman138x's Avatar
1995 XJ Cherokee
Guys....AWESOME!!!! thank you so much for the info. I have nothing to loose so why not tear it apart. Son of sam did you have any kind of noise before you tore the tranny down? Wondering if we both have a transfer case problem beings that you already tore your tranny down. You did say though that you tore it down a while ago it is the same with me, I put the rebuilt in around beginning of 2005
"Yo ho yo ho a pirate's life for me"
xwildman138x is offline
post #17 of 103 Old 08-21-2008, 10:38 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Good luck with your AX15 rebuild. I got a rebuild kit from transparts
via ebay. It included bearings, seals, and synchros. I would suggest
replacing the 5th gear snap ring, do not put the old one back in as they
are a known weakness--get the set of 8 or 10 from the dealer as they
come in varying thicknesses. If you need part numbers when you get to
this I can get them for you. I had access to a full shop with bearing
splitters and several bearing presses which came in handy when I did my
rebuild (military auto hobby shop). I found it took a few days for the
synchros to bed in after the rebuild, I ran standard gear lube GL 4 not
5 as per Pat, for about a thousand miles then switched to Redline MT 90
like Rustywrangler has been known to recommend.
I also rebuilt the NP231 at the same time, it was a simple and
satisfying task.
Take photos, use many ziplock bags and labels for all your parts. You
can even get special markers to be able to write on the parts for
orientation if needed.
Good to know info for Pirates: http://www.talklikeapirate.com/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #18 of 103 Old 08-22-2008, 01:41 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Thats great info thank you. I have been searching the web for the rebuild kits looking at all the different ones. I'll check those guys out next. I'll keep you informed as whats going on. Probably next week I'll tear out the tranny and throw it on the bench
post #19 of 103 Old 08-22-2008, 01:44 PM Thread Starter
xwildman138x
1995 XJ Cherokee
I saw that before. hillarious. I love the people that really get into it. Theres alot of them! Remember this about land pirates we don't burn villages we burn metal. (or in this case a transmission)
post #20 of 103 Old 08-22-2008, 03:25 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Opihi59 is this the kit your talking about? Only one I have seen yet WITH the syncros
http://cgi.ebay.com/ebaymotors/Jeep-...5669QQtcZphoto
post #21 of 103 Old 08-27-2008, 12:01 AM
SonofSam02
thats the one i got when i rebuilt mine. I dont know about the noises, i dont recall any but it was two years ago when i rebuilt it so. Good luck, let us know how it goes
SonofSam02 is offline
post #22 of 103 Old 08-27-2008, 12:24 AM
Opihi59
Opihi59's Avatar
Arrrrrr. I checked my files. Transparts Warehouse Inc (866)223-5656 Bechelli Lane Redding, CA. Kit was $155. Mine included the seals as well. All of them. The person I ended up talking to on the phone was Randy Laskowsky, there is a very knowledgeable person there named Megan. The email add I used to them was transpts@pacbell.net Their part number on my invoice was BK163JWS, and it was Jan of this year I bought it.
Short answer--yes, this is the place.
I don't know why the set looks different from what I got though. Call them ask for Randy and he will help you. Sorry I didn't get this info to you sooner, I didn't see this until just now.
Opihi59 is offline
post #23 of 103 Old 08-27-2008, 12:42 AM
Opihi59
Opihi59's Avatar
Don't forget the snaprings
http://www.jeepforum.com/forum/showt...+gear+snapring
View the photo kloppk put in this thread. It shows where the snaprings go for the 5th gear, both counter 5th gear and mainshaft 5th gear. To be quite honest, I don't know which one of these is notorious for breaking all the time, but I think it is the counter 5th gear snapring that goes toes-up. At any rate, I believe Pat will be able to set us straight if he sees this string. These snaprings come in sets, even though in the parts CD they each have a different part number according to thickness. You need to measure and order the thickest one that will go in. I have all the PN's if you need when the time comes.
Opihi59 is offline
post #24 of 103 Old 08-27-2008, 04:12 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Awesome thanks man, yeah I will be talking to you I'm sure when it gets tore down. I got the tranny back out last night. Tomorrow night I have to make something to support the motor so I can get it off the stands and out of the garage. I have to get my moms ss back in the garage. I'm going to start tearing it down hopefully friday night and I'll be back with my laundry list of questions. Thanks guys
post #25 of 103 Old 08-29-2008, 04:14 PM Thread Starter
xwildman138x
1995 XJ Cherokee
A guy at work is selling me a chevy 350 with tranny that has 24,000 miles on it for 200 bucks. If this rebuild fails then its swap time!
post #26 of 103 Old 08-30-2008, 02:32 PM Thread Starter
xwildman138x
1995 XJ Cherokee
I made this today so I could get the jeep out of my parents garage. I was able to bolt my contraption onto the block and it rests on the frame rails. I think I went a little overboard because its not that much weight but I'll have it for the next time we need to move a jeep and theres nothing to support the motor. Sorry for the terrible cell phone pic, but my phone is on its way out.
post #27 of 103 Old 08-31-2008, 01:24 AM
Opihi59
Opihi59's Avatar
There is never a substitute for overengineering.
Opihi59 is offline
post #28 of 103 Old 08-31-2008, 01:45 PM Thread Starter
xwildman138x
1995 XJ Cherokee
Haha yeah thats what I was thinking!!!
post #29 of 103 Old 09-21-2008, 09:19 PM Thread Starter
xwildman138x
1995 XJ Cherokee
I FINALLY got a couple hours to work on the tranny. I got this far in a couple hours, but now comes the hard part I was looking ahead in the directions and there seems to be a pilot bearing between the input shaft and the output shaft. I'm thinking maybe this could be the problem. This is totally a guess at this point but you can move the shaft up and down pretty good and thats where its moving. There seems to be way too much play in there. The syncros don't look bad and there was only the smallest bit of brass shavings in the bottom (probably from trying to grind it into the garage). I thought for sure there was going to be a broken gear but I haven't seen anything yet. Tomorrow I will tear into it more.
post #30 of 103 Old 09-22-2008, 12:22 AM
Opihi59
Opihi59's Avatar
Don't set your heart on it being that pilot bearing. The shafts are supported in the case at both ends by bearings. With the case off, they lose that support and feel sloppy. Looks like you're off to a good start. Tell-tale pile of ziplok bags......label and photo everything. Get some kinda marker and mark on your shift rods, etc. It can take some anxious time figuring out which is which etc at re-assembly time.
Opihi59 is offline
Gear shift hard to move in neutral when hot spshultz YJ Wrangler Technical Forum 15 02-03-2013 12:02 AM
1990 YJ Auto, hard to shift into neutral or park from drive Nokinja YJ Wrangler Technical Forum 1 08-15-2009 09:30 PM
Tranny grinding, hard shift unideluxe YJ Wrangler Technical Forum 3 12-31-2008 08:11 PM
1993 YJ hard to shift, grinding gears etc...help 1993jeep YJ Wrangler Technical Forum 16 12-02-2006 09:58 PM
AX15 5speed stuck in neutral Help Wingryder YJ Wrangler Technical Forum 5 07-02-2002 10:41 AM
