I did the conversion to the external slave on my '93. I purchased the entire set-up from the dealer for a little over $100 and it was already bled and ready to bolt in. Look for a '95 YJ, they used an external set-up so it should work perfect for you.
I don't care if you lick windows, take the special bus or occasionally pee on yourself...
You hang in there sunshine, you're freaking special.
91/93 YJ's merged 4.0L ax-15 8.8 w/Detroit TB spacer SOA SuperShortSYE
01 Cherokee stock
03 Yamaha R1 "Couldn't catch it if you tried"
