So I drained my tranny today and was wowed to see nothing but mud come out of my tranny. I'm glad I did it and hopes it stops some of the hard shifting I have. Anywho Is there a vent tube on this thing cause i could find one and assume there isnt one because my gear oil looked like mud as it was comin out or do I need to add one somewhere?... Thanks
No just a metal cap that fits kinda loose. I once saw a post on removing it and running a vent line but couldn't find it. Maybe someone else can chime in.
It should have a tube like the axles do, only I don't know for sure that it actually came with one.
If it has the little floating cap, you can remove it & use some hose barbs with the same size thread. (NPT) or National Pipe Thread.
It's prolly 1/8"NPT, Use a 3/16" hose/tube & run it to a tee (hose barb tee) that also connects to the transfer case breather tube.
From there, it should lead to a high spot on the engine side of the firewall.
At this point, you can use another barb & a 1/8" NPT female coupler to re-connect the little breather with the floating cap.
These components will go from hot to cold when you submerge them in water.
Without breathers, the air inside them cools & the vacuum created from that, will suck the water past the seals of the shafts that pass through their cases.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
