ax 5 upgrade - JeepForum.com
post #1 of 10 Old 10-09-2013, 06:27 AM Thread Starter
AltonR
ax 5 upgrade
New guy here & new to jeep tinkering .
I have a bad transmission (ax5)in my otherwise great jeep .
Question ...I here talk of upgrading to ax15.Will the bell housing off the ax5 interchange with the ax15 ?
Assuming I would have to change the transfer case & drive shaft also ?
Already have a good ax15 setting in my shop so would it be cheaper & better to use it than replacing the ax5 ?
AltonR is offline
post #2 of 10 Old 10-09-2013, 06:58 AM
79jeepincj7
1979 CJ7
You running a 4 cylinder or 6? Also the ax5's are a 21 spline output shaft where as the ax15 is a 23 so just be aware of that for your transfer case options. A cj dana 300 was more commonly a 23 spline.
Wheel - Wreck - Wrench - Repeat!
The VIN says its a 79 CJ
79jeepincj7 is offline
post #3 of 10 Old 10-09-2013, 07:31 AM
CSP
What model Jeep is this in?
I can't help but thing you're asking this in the wrong forum and should be in the TJ forum.
CSP is offline
post #4 of 10 Old 10-09-2013, 07:44 AM Thread Starter
AltonR
Well told ya I was new at this .
Cked my title but it doesn't say so it may be a tj .
2.5 engine
Would a mod move this to the TJ forum ?
AltonR is offline
post #5 of 10 Old 10-09-2013, 07:55 AM
79jeepincj7
1979 CJ7
2.5 engine
Lol is your gas tank filler on the left rear quarter? Behind the liscense plate? Or under your right trail light?
Even easier.. what year is it?
post #6 of 10 Old 10-09-2013, 08:10 AM Thread Starter
AltonR
Yes ,gas fills under license plate lr . 92 model .
thanks for the replys .
AltonR is offline
post #7 of 10 Old 10-09-2013, 09:12 AM
jdarg
Bellhousings are not the same on the transmission end. Output shafts on the AX5/AX15 are different spline count so you need to get a 23 spline 231 or change your 21 spline 231 over to a 23 by replacing the input gear.
Google this. There's tons of detailed info out there. Folks aren't likely to recite all the ins and outs again in your thread, especially since a CJ never came with an AX5 so you are in the wrong forum.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #8 of 10 Old 10-09-2013, 09:19 AM
CSP
Your 92 Wrangler would be referred to as a YJ (87-95)
CSP is offline
post #9 of 10 Old 10-09-2013, 10:25 AM
sjones26573
Wrong forum bub. You should be in YJ Tech
EDIT: Wheelin just moved the thread
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #10 of 10 Old 10-09-2013, 11:08 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Threads merged and moved to YJ Forum.
Wheelin98TJ is offline
