AX-5 Trans. Fluid change - JeepForum.com
post #1 of 12 Old 07-08-2011, 06:31 AM Thread Starter
Andywear
Well... I was planning on following the FAQ thread on how to change your trany fluid but I ran in to some time consuming problems.
1-1/2 hours and the only thing I really got done was drinking some beer.
First problem was removing the shift tower to use as the fill port, but you need to first move the TC shifter.
That was a no go. I could only see two up top and 3 on the side to un-bolt but I could only get 4 of them off.
The one I could not budge it’s in a tight spot:7-8jeep-001.jpg
Is that the last bolt to remove to get the TC lever assembly out of the way?
The fill plug is on the Passenger side hard to get to(IDK, might not be as hard as removing the TC lever) thus the idea to use the top shift tower as the fill port.
The drain plug is on the driver side hard to get to.... but what is this plug on the bottom of the trans?7-8jeep-005.jpg
I didn't try to unscrew it figured I'd ask first.
Used to have a good sig but Mod threated to ban me...
Errrrrrr, Will complain else where - &y
Andywear is offline
post #2 of 12 Old 07-08-2011, 09:17 AM
jmmorgan82
2009 JK Wrangler
It's been a few months since I changed my fluid, but you don't have to unscrew the shift tower to remove the shifter. If you remove the dust cover from the top where the shift lever goes into the tower, you will see a round metal bushing. Press down with your thumbs and turn counter-clockwise at the same time and it will pop loose.
jmmorgan82 is offline
post #3 of 12 Old 07-08-2011, 09:24 AM
GRYDE001
save yourself some headaches and just go buy a $4 oil hand pump that fits on top of the gall jugs of oil. My trans oil change took all of 15 m inutes, and most of that time was spent draining the old stuff out and pumping the new in.
edit - this method is used when you use the fill plug, not the shift tower for a filling location
""Leave it stock, it will live longer. Just understand that its never gonna be as fast as a minivan""
GRYDE001 is offline
post #4 of 12 Old 07-08-2011, 09:26 AM Thread Starter
Andywear
Gottca will try.
Thanks
to both post's
Andywear is offline
post #5 of 12 Old 07-09-2011, 08:25 AM
Dlambright
i just used a hose long enough to go from the fill hole to the outside of the tub and stuck the funnel on it. let gravity fill it..takes about 10 min.
Dlambright is offline
post #6 of 12 Old 07-11-2011, 06:23 AM Thread Starter
Andywear
Thanks ya'll
I ended up removing the shifter lever per jmmorgan and it worked great! I was able to clean out a little junk off the bottom of the lever and found out the plug at the bottom of the trans is the drain, there is no drain plug at the rear driverside. (or at least I didn't see it)
Now just need to find a rubber boot to replace the trans shift boot cover.
Andywear is offline
post #7 of 12 Old 07-11-2011, 11:59 AM
jmmorgan82
2009 JK Wrangler
Glad to hear it worked out for ya!
post #8 of 12 Old 07-11-2011, 12:21 PM Thread Starter
Andywear
Besides the original, what is best to replace the shift boot cover?
Andywear is offline
post #9 of 12 Old 05-27-2013, 01:49 PM
p0larb3ar
if you want to replace your shift boot I would say invest in a leather boot. First thing I did when I got my 93 was order a black and red boot from redlinegoods.com
http://www.redlinegoods.com/Wrangler8795shiftboot.php
they were a little bit more than the rubber but ive never had issues with it binding up in the winter since rubber gets hard and leather stays suple
just my $0.02
p0larb3ar is offline
post #10 of 12 Old 05-27-2013, 05:40 PM
StanF
just my $0.02
Great tip on Red Line leather - hadn't seen that before. Don't need one now, but I filed it away for future reference!
StanF is offline
post #11 of 12 Old 05-27-2013, 06:14 PM
Mark05059
just my $0.02
Im sure the person will appreciate your .02 two years after the last post.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 12 Old 06-05-2013, 09:59 PM
p0larb3ar
Well it'll be seen by others too, I learn a lot from just reading the forums old and new
TC and Trans fluid change, what to use? GreenTJ420 TJ Wrangler Technical Forum 2 04-02-2010 09:15 AM
AT trans fluid change tjguy26 TJ Wrangler Technical Forum 5 05-30-2009 02:33 PM
Trans fluid change rickbo TJ Wrangler Technical Forum 3 10-18-2007 08:46 PM
When to change trans fluid rjt36 TJ Wrangler Technical Forum 10 07-10-2006 02:25 PM
need to change trans fluid bonehead99 YJ Wrangler Technical Forum 3 07-23-2002 02:41 PM
