AX-5 Teardown - JeepForum.com
post #1 of 4 Old 01-12-2008, 07:13 PM Thread Starter
djkrash
AX-5 Reverse Head Replacement Procedure
My son broke his reverse head on his '93. Does anyone know where he can find a replacement procedure to get at least that shifter head out? An on-line manual or maybe someone has it and can pm me about for e-mail. Thank you.
djkrash is offline
post #2 of 4 Old 01-12-2008, 07:47 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Cosminciortan - AX-5 Overhaul
http://www.jeepforum.com/forum/f12/ax5-overhaul-write-up-pics-505640/
- Ernie
Richmond88yj is offline
post #3 of 4 Old 01-14-2008, 11:41 AM Thread Starter
djkrash
Taking this back to the top due to editing. Thanks. Dan
djkrash is offline
post #4 of 4 Old 01-14-2008, 12:30 PM
kloppk
Two ways to remove the shifter head.
1) Lift up the round rubber seal on top of the shift tower. While pressing down on the spring loaded retainer turn it CCW. It should then pop up releasing the shifter.
2) If that gives you a hard time just remove the 4 bolts holding the shift tower on the tcase and then lift the assembly out of the tranny.
kloppk is offline
Beginning stroker build - initial teardown madmax79 YJ Wrangler Technical Forum 40 06-12-2009 05:17 PM
Power Steering Pump teardown drew2000 YJ Wrangler Technical Forum 1 11-25-2006 07:36 AM
Engine Teardown@4200 miles 05 ORANGETJ TJ Wrangler Technical Forum 6 02-26-2006 10:53 PM
