AX-5 manual transmission fluid check/fill plug? - JeepForum.com
post #1 of 8 Old 10-12-2009, 03:42 PM Thread Starter
ROADDOG516
Can someone please post a pic of the fill plug on the AX-5. I have the haines man and seen diagrams here but none of them are specific. Is the plug removed with an allen wrench or is it a bolt head? Please help I cant find it thanks...
YJ=THE LAST REAL JEEP!
1966 Willys
1993 YJ
2013 JKU Sahara
ROADDOG516 is offline
post #2 of 8 Old 10-12-2009, 04:38 PM
Matt_vs_YJ
It's a bolt head. DO NOT remove the one with the allen head.
In this pic it's the one just above and to the right of the "5th gear switch"
Call me Matt. I have a YJ.
If you're in the Hampton Roads area of Virginia check out the Middle Peninsula Jeep Association
Matt_vs_YJ is offline
post #3 of 8 Old 10-12-2009, 05:57 PM Thread Starter
ROADDOG516
Thanx a million, out of curiosty what is the one with the allen head do?
1966 Willys
1993 YJ
2013 JKU Sahara
post #4 of 8 Old 10-12-2009, 06:02 PM
TheDustMan
It summons some Oompa Loompas which kick you in the groin when your underneath your Jeep loosening it. Dont do it, lol.
J/K, I dont really know what it does.
TheDustMan is offline
post #5 of 8 Old 10-12-2009, 06:21 PM Thread Starter
ROADDOG516
Id like to know because when I was trying to figure it out I DID loosen it just wanted to make sure I didnt FUBAR anything....
1966 Willys
1993 YJ
2013 JKU Sahara
post #6 of 8 Old 10-12-2009, 06:30 PM
Matt_vs_YJ
It's just a plug that holds a detent ball and spring. As long as they didn't fall out, then you should be ok.
post #7 of 8 Old 10-12-2009, 06:32 PM
Matt_vs_YJ
So that's why that happened... I thought it was just a YJ thing
post #8 of 8 Old 10-12-2009, 06:55 PM Thread Starter
ROADDOG516
Matt thanks for your answers it was a help....no nothing fell out because as soon as I loosened it up, oil came out so I tightened it right back up.....lost about 1oz,,,,at least now I can fill er up the right way...
1966 Willys
1993 YJ
2013 JKU Sahara
Changing Manual Transmission Fluid through fill hole? BrettDez JK Wrangler Technical Forum 11 09-08-2009 03:18 AM
Where is the drain plug and fill plug on manual transmission Mr_E YJ Wrangler Technical Forum 2 07-11-2009 03:26 AM
2004 TJ Manual Transmission Fluid Check Question - What size hex bolt is it? shamons TJ Wrangler Technical Forum 3 05-05-2009 12:49 AM
How do I check my manual transmission fluid/grease? the2040 TJ Wrangler Technical Forum 5 06-30-2008 12:33 PM
95 2.5 manual transmission fill plug mrsneelock YJ Wrangler Technical Forum 2 12-02-2006 08:33 AM
