Quantcast AX-5 Disassembly - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > AX-5 Disassembly
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 01-31-2009, 11:32 PM   #1
95greenrio
AX-5 Disassembly
How do you take the rear casing off of the AX-5? I have all the bolts and nuts off that go around the center section but it slips out about 2" and hangs up on something. It seems like it is getting caught on something on the passenger side of the trans.
Thanks
1995 YJ Rio Grand - work in progress
95greenrio is offline   Reply With Quote
Old 02-01-2009, 08:49 AM   #2
kloppk
Did you remove the...
- Two Restrictor pins
- Shift Lever Shaft Plug
- Shift Lever Shaft bolt
- Shift Lever Shaft
- Housing Shift Lever
These need to be removed before you can get the rear half of the case off.
kloppk is offline   Reply With Quote
Old 02-01-2009, 11:32 AM   #3
95greenrio
-No
-No
-Yes
-No
-Yes
Thanks, I'll give those a try.
Glock Forum
