AX-5 5th gear clip & collar repair without trans removal - Page 7 - JeepForum.com
post #91 of 143 Old 05-17-2012, 10:45 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Yes to RTV (silicone). There is no question here, use the RTV like you did, let it "dry" generally overnite, then fill it.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is online now
post #92 of 143 Old 10-21-2012, 09:16 AM
1v6pony
Wow thank you for this write up... I have a question, On the lower larger 5th gear. Is it supposed to have play in it, SHould I be able to move it around any???
My clip was in place, the smaller 5th gear is toast and the larger lower gear is a little chiped towards the case on the teeth, but it has play in it....
PS, Where is the best place to buy a manual for this trans.
Thanks for the help.
Brad
1992 Wrangler 2.5 ax5
1v6pony is offline
post #93 of 143 Old 10-21-2012, 10:02 AM
1v6pony
OK, here is another question, The fith gear and the lower counter gear will they come off towards the back of the case?
Or I should say, will they come off the shafts without haveing to remove all the rest of the gears towards the front of the case?
Does this make since???
Thanks Guys
1v6pony is offline
post #94 of 143 Old 10-22-2012, 01:57 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks Guys
They both come off to the rear.
If the countershaft gear (the lower one) has too much play, you'll need a new clamshell bearing.
Get an FSM for a manual.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #95 of 143 Old 07-13-2013, 04:16 PM
kyhawk
I seem to be having a small problem/problems. I don't know if it's just my luck, but first I couldn't get the skid plate loose due to the bolt free spining(nuts rusted free on the inside of the frame), so I decided to do it without removing it, and lots of fun later I have finished the repair but during reassembly I cannot seem to get the shift fork to drop into the right spot. Do I have it stuck in gear or something becaust for the life of me I cannot get it to line up right. Any help would be greatly appreciated.
Does anyone have any help on this one? I am havng the same issue.
kyhawk is offline
post #96 of 143 Old 08-16-2013, 08:11 AM
warrior1317
So last week I lost fifth gear in my AX5. Thinking it was the typical snap ring issue, my dad and I dove into it last night only to discover that the snap ring was still in place. Though it did have some "wiggle" room, there was no obvious sign of wear and tear or problem. Any other thoughts on why fifth gear would go out? Is "wiggle" room enough to lose fifth?
warrior1317 is offline
post #97 of 143 Old 08-16-2013, 05:53 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, I've seen this before as well. The fifth gear hub on the cluster shaft (lower shaft) has had it's splines stripped off.
Pull the lower assembly & you'll find your issue.
Max
Mean Max is offline
post #98 of 143 Old 08-16-2013, 06:51 PM
warrior1317
Originally Posted by Mean Max
Yes, I've seen this before as well. The fifth gear hub on the cluster shaft (lower shaft) has had it's splines stripped off. Pull the lower assembly & you'll find your issue. Max
Thanks. Plan on getting back into it tomorrow morning.
post #99 of 143 Old 08-18-2013, 09:27 AM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Max
Mean Max is offline
post #100 of 143 Old 11-08-2013, 01:25 PM
biggunn
New to the forum but have referenced it many times over the years. I have to say you guys are absolutely the best. I just did the father/son challenge and rebuilt my son's ax-5 tranny because the synchro's had gone out in all gears but 5th. We re-installed it and everything worked better than it ever had and we were stoked. I guess the strain was too much for the 5th gear snap ring though and after a day of driving it popped out of 5th gear and is difficult to engage. I was glad to see I can repair without dropping the tranny again. I looked for the parts listed earlier in the thread and couldn't find the company so I ordered the parts from http://www.allstategear.com Part numbers are ax5-srk (Snap Ring Kit $10) and ax5-srr (Snap ring retainer $22). Cost with shipping and tax was $48. They are located in San Antonio, TX. Should get the parts on Monday and will already have it apart by then so installing should be a snap. Thank you all for your help. Learned a lot rebuilding my tranny and got to punch a slot on my man card.
biggunn is offline
post #101 of 143 Old 11-11-2013, 08:17 PM
biggunn
Hey guys I'm hoping someone can help me out here. I have an ax-5 tranny that we just put new synchros and bearings on. Put it all back together and installed it and it worked perfectly, everything worked well until he went to put it into 5th. I thought the clip must have broke after reading your post (which was great by the way) but when I opened it up everything looks right. When I drove it I could feel it go into the 5th gear slot but it would grind a little and I actually got it in 5th gear but it would easily pop out of 5th gear on it's own. I have all the 5th gear parts on the table in front of me and I cant see any major problems. 1st 2nd 3rd 4th and reverse all work great. when I took the back of the case off I pulled out the 5th gear by hand and it shifted easily. This is my first tranny to rebuild so go easy on me. I can post pics if you need me to show you anything. Any help would be appreciated.
Moved my question to it's own thread. http://www.jeepforum.com/forum/f12/a.../#post17641129 I don't know how to delete this.
biggunn is offline
post #102 of 143 Old 11-11-2013, 08:33 PM
biggunn
I need to add, when I first put it together and tried bench testing it and it wouldn't shift at all. When I turned the shaft I could tell reverse was engaged even though all my rod ends were aligned where the shift leaver goes. I pushed in the reverse rod and it seemed to fall into place like the detent ball was in a bind then everything shifted fine, even 5th so I thought I was good to go. I don't know if that plays into the current problems but wanted to add it just in case.
biggunn is offline
post #103 of 143 Old 06-02-2014, 09:12 AM
Brad_YJ
Has anyone ever had a problem with collar?
Hi and thank you all greatly (esp. MadMax and Opihi59)
I had an AX-5 5th gear issue (clip replaced by others several times) & am ready to try the collar.. But after seeing the following post:
http://www.jeeps-offroad.com/showthread.php?t=3895
I am curious if anyone has had a problem with the collar failing. It seems like if this were to fail (or loosen over time), there would be serious problems!!!
Do you guys suggest using "locktight" on the collar screws? If so what type?
Also, is there a torque spec for this... I haven't ordered it yet, so I'm not sure if it comes with instructions.
Thanks a bunch!
1995 YJ...
Brad_YJ is offline
post #104 of 143 Old 06-02-2014, 03:10 PM
Bearybee
Thanks a bunch!
1995 YJ...
I am considering trading a 2001 WJ for a 95 YJ that does not have 5th gear. I have researched a lot about this the last couple of days and have not come across anyone saying bad things about the collar. The person who made that post on the other forum posted that 10 years ago. I am sure there's been a lot of time for it to show it's ugly face if there was an issue.
Bearybee is offline
post #105 of 143 Old 06-02-2014, 04:47 PM
Opihi59
Opihi59's Avatar
Brad YJ--Locktite on the fasteners is a good idea. General rule of thumb at least for me is that if I will not have routine/easy access to that particular fastener, it's prolly a good idea to locktite it. That goes for various internal bolts inside transmissions I rebuild, flywheels, etc. For locktite to work properly, you need to have clean/dry threads on both internal and external threads. I use brake cleaner, then compressed air. Repeat as necessary and don't get it in your eyes.
Clutch Pedal Clip Removal pointblanke TJ Wrangler Technical Forum 7 08-25-2011 08:44 PM
U Joint retainer clip removal help YJames90 YJ Wrangler Technical Forum 3 07-27-2009 07:04 PM
c clip removal amajeeptour YJ Wrangler Technical Forum 2 07-07-2009 07:54 PM
Front clip removal jeepwrnglr92 YJ Wrangler Technical Forum 7 11-21-2007 12:23 PM
Dana 35 C-clip Axle removal Paulwpetrea YJ Wrangler Technical Forum 2 08-21-2002 10:54 AM
