AX-5 5th gear clip & collar repair without trans removal - Page 5 - JeepForum.com
post #61 of 143 Old 09-14-2011, 06:27 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Just like NBfarmboy described above, it sounds like you stripped the splines on the shaft, and/or countershaft 5th gear. YOu have the trans apart, what happens when you manually move the 5th gear synchro sleeve between 5th/reverse? Does it lock onto 5th spline gear, or does that assembly spin freely? Does your shift fork slide on the shift rail, or is it properly "fixed." Likely you stripped the splines off the gear/shaft.You say it looks intact. It isn't. Pull off that snap ring on the counter shaft, and use a puller to remove 5th spline gear and 5th counter gear/shift hub and tell me what you find, but try sliding the synchro sleeve over the counter 5th first and see if it doesn't free spin (if it is "normal" it shouldn't spin....)But confirm for me that what you have is an AX 15, and not an AX 5.
Just saw your photos, we were posting simultaneously. You have an AX 15, which would be expected behind your 4.0 you listed in your profile. Check your PM later, not sure I can send a PM via work/firewall.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #62 of 143 Old 09-15-2011, 05:42 PM
NBFarmboy
Originally Posted by Opihi59
I have experienced exactly that same defect X 2 on a Toyota W50 5 speed. That particular transmission is also Aisin and very very similar to the AX5 including its weaknesses. Of course you will need a new cluster gear, likely a 5th gear, and should put in a rebuild kit while you're at it as well as replacing the snapring while you're in it if you're planning on keeping the Jeep.
The second repair I did on my 81 trans was to take the 5th gear to a machine shop and had them cut me a keyway down the inside of the gear with a wire EDM, then I hand cut a matching keyslot in the shaft with a die grinder/cut off wheel, made a key, put it back together and ran it for years. This was back in 1983.
Ahh edm machines
That brings me back to my days in machine shop there haha
I'm looking for an ax15 or one of the new 6 speeds for it
Stalking your thread from the comforts of my tractor .... seriously!!!!
RAYS 4X4, an Official MCE dealer, Pm me for prices
"Redneck Rooster" 98 TJ with 5.3 Vortec, 4 speed, 37"s
Wifes "Ladybug" 95 YJ 2.5, 3.5" fenders, 33's, 1" body lift, 1" deep skid pan, york OBA 1" shackle lift
"Bullfrog" 88 XJ 4.0, Doorless, 2" lift, 33-10.5 tires, very cut fenders...
NBFarmboy is offline
post #63 of 143 Old 10-04-2011, 02:28 PM
gordy
Need some help with this,,,
i went to a jeep shop in my area, looking for the clip,, the guy knew just what i was talking about. when i got there he had two?? so one is smaller than the other. where does this go? could someone also help out with a photo of just where the clip or clips go??? that's the only part of this whole thing, i'm a little worried about.
gordy is offline
post #64 of 143 Old 10-04-2011, 04:00 PM
Opihi59
Opihi59's Avatar
I seem to recall photos of just what you're asking earlier in the thread, I just can't see them to direct you due to work firewall limitations.
Opihi59 is offline
post #65 of 143 Old 10-04-2011, 04:36 PM
gordy
yeah,, i looked threw all of them,, i've never done any work like this before and just can't make out, where the rings go,,,
gordy is offline
post #66 of 143 Old 10-04-2011, 05:19 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
The large clip actually holds 5th gear on the mainshaft, the smaller clip is probably the clip for the 5th gear counter gear located on the countershaft directly below the mainshaft.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #67 of 143 Old 11-26-2011, 11:39 AM
Jeepfan1
collar fitment on AX15 shaft
Anyone ever find out for sure if that collar will fit on a AX15 shaft as well?
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #68 of 143 Old 11-26-2011, 06:22 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
No, the clamp will not fit an AX-15 5TH gear.
But I can see no reason to fit one to an AX-15 though, it has never been an issue with them.
Max
Mean Max is offline
post #69 of 143 Old 11-26-2011, 07:00 PM
Jeepfan1
Max
Cool thanks for the reply
/l , [____],
|---L--OlllllllO-
()_) ()_)==O=)_)
Jeepfan1 is offline
post #70 of 143 Old 01-01-2012, 11:08 PM
fixnstuf3
looks like my transmission did the same thing, but i didnt realize there was a kit to help fix this. so ill run with the new clip till it brakes again. thanks!
fixnstuf3 is offline
post #71 of 143 Old 01-02-2012, 07:18 AM
nibstools
I think the newer clips are better quality, so you'll likely never have to worry about it again. but the collar is an extra level of security.
Check out "my little YJ" in the Jeep builds section.
http://www.jeepforum.com/forum/f22/my-little-yj-1127802/
nibstools is offline
post #72 of 143 Old 01-03-2012, 07:57 AM
fixnstuf3
well the clip i put in was from another doner AX5
post #73 of 143 Old 01-03-2012, 11:30 PM
fixnstuf3
just got everything in the jeep today and it is shifting horribly, dosent want to move around, and it wont go in 5th at all now.
post #74 of 143 Old 01-03-2012, 11:54 PM
Opihi59
Opihi59's Avatar
If you only took off the rear case, and it shifted fine into all the other gears, that certainly does not make much sense unless you didn't seat the end of the shifter into the shift forks properly--but that would be hard to do. Do you have Neutral?
Before you put the rear case back on, and installed, were you able to move the 5th shifter hub back and forth by hand to engage/disengage 5th gear? It may be best for you at this point to start a new thread and discuss your problem so we don't clutter up a "How to" thread. I'll look for your new post, or PM me with a link.
While this is not likely to be your current issue, it isn't a great idea to re-use an old snap ring here, as they are so prone to breakage. These snaprings also come in a variety of thicknesses that you should match to the ring gap once the gear is back on the shaft. This list I compiled for the AX 15 as that is where I happen to spend my time, but you should get the idea. I haven't had a need to do it for the AX 5 yet.
There are a lotta numbers associated with all the AX 15 snap rings, hopefully they transmit without too much confusion. They are marked A, B etc on the ring itself with an acid mark.
Snap ring for front bearing (Input shaft)
A- 2.10-2.15 mm 0.0827-0.0846 inches PN 8350-6099
B- 2.15-2.20 0.0846-0.0866 8350-6214
C- 2.20-2.25 0.0866-0.0886 8350-6215
D- 2.25-2.30 0.0886-0.0906 8350-6216
E- 2.30-2.35 0.0906-0.0925 8350-6217
F- 2.35-2.40 0.0925-0.0945 8350-6218
G- 2.40-2.45 0.0945-0.0965 8350-6219
Front bearing on cluster gear
A- 2.00-2.05 0.0787-0.0807 PN 8350-6081
B- 2.05-2.10 0.0807-0.0827 8350-6082
C- 2.10-2.15 0.0827-0.0846 8350-6083
D- 2.15-2.20 0.0846-0.0866 8350-6084
E- 2.20-2.25 0.0866-0.0886 8350-6085
3-4 Synchro Hub snap ring
A-1.80-1.85 0.0709-0.0728 PN 8350-6086
B- 1.85-1.90 0.0728-0.0748 8350-6087
C-1.90-1.95 0.0748-0.0768 8350-6088
D- 1.95-2.00 0.0768-0.0787 8350-6089
E- 2.00-2.05 0.0787-0.0807 8350-6090
F- 2.05-2.10 0.0807-0.0827 8350-6091
G- 2.10-2.15 0.0827-0.0846 8350-6092
1-2 Synchro Hub snap ring (there is no “A”)
B- 2.35-2.40 0.0925-0.0945 PN 8350-6093
C- 2.40-2.45 0.0945-0.0965 8350-6094
D- 2.45-2.50 0.0965-0.0984 8350-6095
E- 2.50-2.55 0.0984-0.1004 8350-6096
F- 2.55-2.60 0.1004-0.1024 8350-6097
G- 2.60-2.65 0.1024-0.1043 8350-6098
5TH Gear snap ring (13 of them, there is no “I” in this sequence. In another source, there is an I listed, and the sequence goes only to “L” Caution is indicated here as I do not have a way of reconciling this variance. The astute Jeeper will notice there is a predictable progression in the thickness measurements, as well as the PN’s here. Hopefully this will not derail a project, but in the end, you may need to purchase 2 sequential parts to get the one you need.
A- 2.75-2.80 0.083-0.1102 PN 8350-6268
B- 2.80-2.85 0.1102-0.1122 8350-6269
C- 2.85-2.90 0.1122-0.1142 8350-6270
D- 2.90-2.95 0.1142-0.1161 8350-6271
E- 2.95-3.00 0.1161-0.1181 8350-6272
F- 3.00-3.05 0.1181-0.1201 8350-6273
G- 3.05-3.10 0.1201-0.1220 8350-6274
H- 3.10-3.15 0.1220-0.1240 8350-6275
J- 3.15-3.20 0.1240-0.1260 8350-6276
K- 3.20-3.25 0.1260-0.1280 8350-6277
L- 3.25-3.30 0.1280-0.1299 8350-6278
M- 3.30-3.35 0.1299-0.1319 8350-6279
Opihi59 is offline
post #75 of 143 Old 03-20-2012, 09:25 PM
stompjrkz400
i pulled my ax5 apart today, i bought it without 5th gear, ( it would click ) i was hopping it was just the clip, and no damage, turns out the clip was fine, but 5th gear wasn't, i just ordered a gear set that comes with the 2 gears, im going to order a clip, is there anything else i need? this is my first time getting into a transmission, im actually doing a frame up on the jeep so i can take it wheeling in 3 month at rausch creek, bought it for 300 bucks with a bad frame
i think i need to find a new skidplate/ crossmember too
stompjrkz400 is offline
Clutch Pedal Clip Removal pointblanke TJ Wrangler Technical Forum 7 08-25-2011 09:44 PM
U Joint retainer clip removal help YJames90 YJ Wrangler Technical Forum 3 07-27-2009 08:04 PM
c clip removal amajeeptour YJ Wrangler Technical Forum 2 07-07-2009 08:54 PM
Front clip removal jeepwrnglr92 YJ Wrangler Technical Forum 7 11-21-2007 01:23 PM
Dana 35 C-clip Axle removal Paulwpetrea YJ Wrangler Technical Forum 2 08-21-2002 11:54 AM
