AX-5 5th gear clip & collar repair without trans removal - Page 2 - JeepForum.com
post #16 of 143 Old 12-01-2009, 01:04 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Originally Posted by turtlerace View Post
That's not carnage, that is a unintentional access port.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #17 of 143 Old 12-01-2009, 03:19 PM Thread Starter
Mean Max
Don't poke the bear
Mean Max's Avatar
Originally Posted by UltimatE View Post
Ooohh OOohhh can I play?
Nice!
Max
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #18 of 143 Old 12-01-2009, 07:02 PM
mottern
Im in the process of doing the same thing on my YJ. Got the collar from consolidated transmission, very fast shipping. Turns out the genius that owned the jeep before me welded the 5th gear snap ring to the output shaft,needless to say it didn't work and made a mess of things. Also ordered a rebuild kit of Ebay cause second gear has been grinding and thought I might as well fix it while I was in there. Luckily I have a reliable bicycle to get me back and forth while I fix it
"The wise man does at once what the fool does finally"
1995 Rio Grande YJ 2.5L TRANNY-RX-5
mottern is offline
post #19 of 143 Old 05-22-2010, 08:51 AM
hugs28
ok I know this is an old post, but we are having trouble with the 5th gear in our ax-5 trans. I read this whole post and I see it gives where you can get the parts etc.... however I am having a very hard time finding them. Consolidated Transmissions I can't find and they don't answer the phones. Can anyone give me an actual website or phone number that works for finding the parts. I have searched and come up with nothing. thanks all
hugs28 is offline
post #20 of 143 Old 06-01-2010, 09:13 AM
skreeks
Is there a gasket that will have to be replaced when you split the tranny? Or is it just sealed with silicone?
skreeks is offline
post #21 of 143 Old 06-01-2010, 09:20 AM
YJake
RTV all the way!
Jake
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #22 of 143 Old 06-04-2010, 01:28 PM
kiitanak
just ordered my kit, finally!!!
kiitanak is offline
post #23 of 143 Old 06-12-2010, 11:01 AM
AngryBassets
AngryBassets's Avatar
From who?
Mine went out yesterday.
stale milk white 97 Police Package XJ (former FD gofer vehicle) bought in 11/08 w/ 41.6k**95 YJ 4cyl/5spd summer beater
Past Jeeps:97 XJ Sport 6cyl/auto, 00 TJ 6cyl/auto,95 YJ 4cyl/5spd 95 XJ SE 6cyl/auto, 93 YJ 4cyl/5spd
AngryBassets is offline
post #24 of 143 Old 06-12-2010, 11:45 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Originally Posted by Mean Max View Post
Okay guys, here is the info on sourcing the locking collar & clip.
The collar part number is:
AX5SRK and costs $34.50
The snap ring (1 required) is:
83500592 and costs $4.00
The replacement gear set (5th gear & counter gear) is:
G525 and costs $109.35
These parts can be sourced from:
2850 W Airport Blvd
Sanford, FL 32771-1610
(407) 321-2055
(800) 578-8726
Ask to speak to Brandon, his family owns & operates Consolidated Transmissions and he will gladly assist you in getting the right parts to get you going!
Max
Check post #9 (qouted above) from this present thread. I doubt the numbers have changed, but if they have, please post in your findings.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #25 of 143 Old 06-12-2010, 02:10 PM
kiitanak
the collar is $38 now, snap ring is still the same
kiitanak is offline
post #26 of 143 Old 06-18-2010, 10:35 PM
juangolf
hey guys, i just had my synchros done, about 2 weeks ago, and first when i drive for a long time, putting the jeep on first gear makes a big loud noise, like the gear going in with high pressure i donno.. any suggestions? and now, my fifth gear just kicks off when trying to engage it, i have tu try many times for it to stay on? did i loose the fifth gear clip?? i have warranty so i just need to know what is it and they will fix it, as long as is tranny related.
please let me know guys what u think..
juan
juangolf is offline
post #27 of 143 Old 06-30-2010, 12:47 PM
Matt The Hammer
Max- Collar and clip is finally in hand. I also bought two dead AX5 transmissions to use as a reference/practice units before I open my good one in the Jeep.
10W-30 instead of gear oil?
The upgrade in smell is worth the change alone. Gear oil (sulphur) smells sooo bad. Just thinking about it again... ugh.
EDIT
Search function is your friend as 10W-30 is the correct oil to use. Thanks again Max.
2013 JKU
1995 YJ
Matt The Hammer is offline
post #28 of 143 Old 07-07-2010, 01:56 AM
SunDevilJeeper
Originally Posted by Matt The Hammer View Post
Last time my AX had 5th gear... Bill Clinton was in office.
Hope it's still ok.
Problably lonely.
Overdrive here I come! Thanks again Max. I'll post pictures of my 5th gear adventure.
jeeeezus, you're kidding right?
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #29 of 143 Old 07-07-2010, 01:59 AM
SunDevilJeeper
5th gear went out for me a few days ago, i was on a downhill on the I-10 in 5th going about 65 and i started hearing a grinding noise which turned into a really loud rapid clacking noise.
i sure as hell hopethis is the problem, otherwise im'a be pissed. lol.
post #30 of 143 Old 09-13-2010, 08:11 PM
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I just had a similar problem. I was driving down the freeway in 5th and suddenly there is this loud metal banging sound. I turned off the AC..nothing. I grabbed the shifter and its vibrating really badly. I downshifted to 4th...noise stops. Every other gear works but 5th sound like gears are not engaging. This write up sounds like my solution.
Thanks for the info Max.
But it seems like it would be easier to simply remove the transmission by unbolting the bellhousing. Am I wrong?
If not, why is it necessary to remove the shifter, transfer case shifter, and the shifter tower from the gearbox?
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers,
, custom cv driveshafts,
, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s,
, Teraflex Bellyup,
, rock lights, RE hand throttle, M.O.R.E. roll cage,
, 9000lb winch with synthetic cable
(12voltguy.com), Dual Blue Top Optimas with
dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline
Clutch Pedal Clip Removal pointblanke TJ Wrangler Technical Forum 7 08-25-2011 08:44 PM
U Joint retainer clip removal help YJames90 YJ Wrangler Technical Forum 3 07-27-2009 07:04 PM
c clip removal amajeeptour YJ Wrangler Technical Forum 2 07-07-2009 07:54 PM
Front clip removal jeepwrnglr92 YJ Wrangler Technical Forum 7 11-21-2007 12:23 PM
Dana 35 C-clip Axle removal Paulwpetrea YJ Wrangler Technical Forum 2 08-21-2002 10:54 AM
