AX-5 5th gear clip & collar repair without trans removal
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | ONBOARD-AIR.COM: Economy OBA System | **Best prices on Yukon Axle & Gears** |
#1 | ||
This is a write-up on how to install the clip & collar kit on an AX-5 that has lost 5th gear. However, the AX-5 pictured here had much more severe issues & required a full rebuild, but being as I had intended on making this write-up I'll go through the procedure for the benefit of anyone who may need to perform it.
My friend & fellow JF member YJake lost 5th gear on his AX-5 recently. We assumed that he just lost the clip & the gear slid back on the shaft, thus losing it's engagement and resulting in a loss of 5th gear. So he bought the clip & collar kit and we started the repair, with the AX-5 still installed in the Jeep. First pull the skid plate off, drain the fluids from the transmission & tranfer cases, remove both driveshafts & unbolt the transfer case. ![]() Remove the shifter, transfer case shifter, and the shifter tower from the gearbox. ![]() ![]() Remove the bolt from the shifter arm that attaches it to the pivot/slide shaft. ![]() Remove the 2 spring loaded shift detent assemblies. ![]() Remove the allen plug at the rear of the transmission case. This will allow you access to remove the pivot/slide shaft. After removing the pivot/slide shaft you can pull the shifter arm up & remove it from the transmission case. ![]() Now you're ready to remove the rear case cover. There are 7 bolts and 1 nut around the perimeter of the case holding it on. ![]() Okay, so this is a picture of a 2WD AX-5 output shaft from a disassembled gearbox, but it shows the 5th gear shift fork & syncronizer (large diameter gearset at the bottom) and the actual 5th gear (small gear on output shaft) and the clip that is supposed to retain it on the output shaft. The clip on the small gear (5th gear) is the clip that frequently falls off. ![]() When the clip falls off, the small 5th gear will slide back on the shaft & lose contact with the larger counter shaft gear that drives it. This is why 5th gear feels like neutral under those conditions. If there has been no damage to the gears, the 5th gear can be tapped back into place on the shaft & a new clip installed. Installing the aluminum 2 piece collar (shown loosely attached here) will prevent a repeat performance. As you can see here, this was not an option for us. ![]() ![]() Reverse the disassembly order to reassemble & refill the transmission with 10W-30 motor oil and ATF in the transfer case. Hope this helps! Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#2 |
That picture of my ground away gears will haunt me in my sleep for days to come
/l , [____], l---L--[]lllllll[]-_ ()_) ()_)==@=)_) |
#3 | |
Instant Gator
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you. 2006 Liberty Sport CRD 1979 J10 LWB |
#4 | |||
![]() ![]() Max ![]()
#5 |
from here it gets rough
Very nice Max !! Post up the source for that 2-piece collar, I know you've done it before, I seem to recall Consolidated Transmissions or something ladat. With this writeup, everyone who owns a wrench should be able to tear the rear of their case off and fix that broken snap-ring/add in the 2-piece collar upgrade without having to pull the whole tranny.
![]() Unless of course, they find gear soup in the rear case half like you did. ![]() ![]()
....I'm not smart, but I can lift heavy things....... Fill out your PROFILE, and don't forget to look in the FAQ for writeups I'm stuck on da Rock http://www2.hawaii.edu/~cbird/Opihi/descrip.htm My Boy Scout Troop site: http://t-304.blogspot.com/ Something bad happened to my photobucket account (..it was my fault...)and all my pictures went blank. I am committed to editing all my writeups and posts to put the photos back in. Let me know if you find a post that needs revision and I will do that one ASAP Currently I believe I have all the critical ones done. |
#6 |
Got my eye on you.....
Is it a similar setup on the AX-15 or totally different???
http://i131.photobucket.com/albums/p...k_banner-1.gif Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08 |
#7 |
Thanks for the write up!
#8 | |
Anyone else have any input on this?
#9 | ||||
The collar part number is: AX5SRK and costs $34.50 The snap ring (1 required) is: 83500592 and costs $4.00 The replacement gear set (5th gear & counter gear) is: G525 and costs $109.35 These parts can be sourced from: Consolidated Transmissions 2850 W Airport Blvd Sanford, FL 32771-1610 (407) 321-2055 (800) 578-8726 Ask to speak to Brandon, his family owns & operates Consolidated Transmissions and he will gladly assist you in getting the right parts to get you going! Max ![]()
#10 |
Well done Max!
I'm sure you just saved people thousands of dollars in transmission work at a shop with this thread! To whoever does this repair, enjoy it! Some of us lost a lot of sleep in the process of making this write up ![]()
#11 | ||
It was a busy weekend, but many lessons were learned & friendships were strengthened. It all makes for a good day! Max ![]()
#12 |
Resident Audio Guru
-Matt White '94 YJ Sport Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar Project (s)Low - A build log. |
#13 |
Instant Gator
That's not carnage, that is a unintentional access port.
#14 |
Max, thank you for posting this! When I have some free time I'm probably going to do this on mine. 5th gear is probably useless for me with the new tires but I'd like to fix it anyway.
1990 Jeep Wrangler YJ - my yj - rescued, rolled, and finally finished 2001 Mustang GT Vert (supercharged) 2004 Lincoln Aviator (daily driver) 2006 Yamaha V Star 1100 Custom 1974 Volkswagen Super Beetle (sunroof and 1904cc motor) 1972 Volkswagen Super Beetle (wolfsburg edition) |
#15 |
Last time my AX had 5th gear... Bill Clinton was in office.
Hope it's still ok. Problably lonely. Overdrive here I come! Thanks again Max. I'll post pictures of my 5th gear adventure.
OBEY FEZ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
