ax-15 won't shift when driving - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > ax-15 won't shift when driving
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 12-25-2013, 08:47 PM   #1
silver03cobra
Just got done putting a used transmission. Drove great until today (3 days) when it's running it won't shift... like clutch won't engage. Is that slave or master??
silver03cobra is offline   Reply With Quote Quick reply to this message
Unread 12-25-2013, 09:10 PM   #2
plym49
You probably need to provide specifics to help diagnose the problem.
If the Jeep is stationary with the motor running, when you depress the clutch can you easily get the tranny into first or reverse?
If you can, your clutch master and slave are working.
plym49 is offline   Reply With Quote Quick reply to this message
Unread 12-25-2013, 10:49 PM   #3
silver03cobra
First no.. 3rd yes... reverse. ... not easy.. I dove it home in 3rd and just skipped the clutch.. until I had to stop.. it didn't like shifting.... motor off trans feels good
Unread 12-25-2013, 11:44 PM   #4
plym49
That sure sounds like the clutch disk is dragging.
Have you checked fluid level in the slave master?
If the clutch was working fine before you swapped the trans, then most likely there is an assembly error as it is unlikely that the clutch hydraulics would coincidentally fail at the same time.
Unread 12-26-2013, 12:37 PM   #5
silver03cobra
I drove it for 3 days no problem. ... slave problem? Fluid level has gone down...
Unread 12-26-2013, 12:39 PM   #6
silver03cobra
Could it be pulling air???? It pulls a little when clutch is depressed
Unread 12-26-2013, 04:10 PM   #7
silver03cobra
Just drove it.. shifts fine... wtf?
Unread 12-26-2013, 11:02 PM   #8
plym49
See #4 above.
You accidentally have an assembly error, the system is low on fuid and perhaps needs to be bled, or you won the lottery and the slave system decided to fail coincident to your working on the transmission.
Or, your floor mats are bunched up under the clutch pedal, preventing full movement.
But it sure sounds like the clutch disk is dragging.
Unread 12-27-2013, 01:08 AM   #9
silver03cobra
No.... administration please delete this... it will just mess people up... I had hard wired my lights and the clutch pedal was hitting the relay.... it's good now... sorry thanks for your help!
Unread 12-27-2013, 06:42 AM   #10
Mark05059
glad you got it fixed... sometimes it just takes people having you check areas that you had not thought of... glad you didn't smash the relay pushing the clutch in
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline   Reply With Quote Quick reply to this message
