AX 15 troubles - JeepForum.com
post #1 of 10 Old 02-09-2013, 08:18 PM Thread Starter
Gunnrunner99
AX 15 troubles
Darn thing wont stay in 4th gear when i apply gas even if I hold I it in gear. Has anyone had similar problems? Thanks for any suggestions.
Gunnrunner99 is offline
post #2 of 10 Old 02-09-2013, 08:28 PM
jhartley
Maybe a bad syncronizer
jhartley is offline
post #3 of 10 Old 02-09-2013, 10:03 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, 4th gear syncro is my bet.
Time to rebuild.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 10 Old 02-09-2013, 10:07 PM
austin6137
1990 XJ Cherokee
Don't use 4th gear
90 - xj laredo- 4.5" rough country lift, 6.5" of total lift with drop brackets, zj disc brakes on c8.25, olympic winch bumper, jcr upper and lower quarter armor, IRO hack-n-tap and rock sliders and rear bumper. rugged ridge 8500lb winch. Spartan locker up front. With a jd yellow paint job, 97+ front end and bushwacker cut out flares. 35's
austin6137 is offline
post #5 of 10 Old 02-10-2013, 08:20 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I can't imagine a syncro making it go out of gear, since they only get paid to help you get into gear. You might try a fluid change to some good stuff. I know years ago mine was acting up, I swapped in synthetic fluid, and over a few weeks it cleaned up nicely, lasted years afterword.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #6 of 10 Old 02-10-2013, 09:21 AM
jhartley
What would cause it to jump out of gear. The shift ring has to get past the syncronizer to engage the gear, the ring may not be toutching the gear and the syncronizer may be kicking it back out. I hope it's something simple as an oil change, it would be the first thing I would try too
jhartley is offline
post #7 of 10 Old 02-11-2013, 05:41 PM Thread Starter
Gunnrunner99
Thanks for replying guys.First let me give the paticulars. Tranny has been freshly rebuilt. Not by a professional I have to admit I did it. Followed Moses Ludel 's step by step. New synchros new keys new 5th gear. outside of 4th performs flawless. I must have missed something didn't spit 4th prior to my rebuild. I am stumped. Does anybody have an idea what I missed or messed up? Thanks Fellas.
post #8 of 10 Old 02-11-2013, 05:55 PM Thread Starter
Gunnrunner99
Just a quick question. Will a faulty ECM cause occasional miss fire.ometimes it purrs then out of the blue will miss bad. Kinda smooths out at about 1500 rpm. Damn thing is like being in love a beautiful woman that just happens to be crazy as hell. You keep thinking i can love her all better.
post #9 of 10 Old 02-11-2013, 08:58 PM
jhartley
I used Moses's guide too my 2nd gear is a little stiff I'm hoping it will get better as the weather gets warmer has it done this since you installed the tranny. May remove the shift boot and see if it stays in 4th
jhartley is offline
post #10 of 10 Old 02-11-2013, 09:00 PM
jhartley
Do you have any codes
jhartley is offline
