AX-15 Trans Question - JeepForum.com
post #1 of 8 Old 02-20-2010, 09:04 AM Thread Starter
DDove
I found an older ax-15 still mounted to a np24tc at a bone yard for 150. I checked the number on the trany and it appears to be out of a early or late 1980's wrangler. I cant be sure. It feels good and it seems the gears are good. My question is: Is there really any way to "check" that tranny. I would just keep the tc as a spare or whatever. I have a 94 2.5 that 5 gear is gone and the syncros in third are shot. Do I get the collar, clip and syncros for my ax-5 or go with the ax-15. Im I just band-aiding the ax-5. As always thanks alot the help.
ps. I do know for sure that it is out of a wrangler not anything else
again thanks
DDove is offline
post #2 of 8 Old 02-23-2010, 11:31 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Moved to your own thread for ya.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 8 Old 02-23-2010, 12:15 PM
RikRotorhead
again thanks
FYI your 4 banger is an AX-5. The swap can be made with a bell housing from a Dodge Dakota with the 2.5 in it.
The AX-5 is a weak tranny.
The AX-15 didn't appear in the Wrangler until very late '89 early '90. Before that it was the BA10/5. The spline count is different.
The BA10/5 and AX5 are both 21 spline, and the AX15 is 23, so if you replace the tranny with an AX15, you will need an NP231-J transfer case. Not the np207 or np231/amc. they are both 21 spline and will not work with the AX15.
Hope that helps.
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #4 of 8 Old 02-23-2010, 12:28 PM
monkeyhouse
Hope that helps.
interesting, I didn't think you could use an ax-15 behind a 2.5L. Good to know.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #5 of 8 Old 02-23-2010, 12:29 PM
rustywrangler
http://www.jeepforum.com/forum/f12/2...mplete-659386/
post #6 of 8 Old 02-23-2010, 12:33 PM
RikRotorhead
Originally Posted by rustywrangler View Post
You're FAST!!
RJC#512
post #7 of 8 Old 02-23-2010, 10:10 PM Thread Starter
DDove
Thanks. This site is the BEST!!!
DDove is offline
post #8 of 8 Old 02-23-2010, 10:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yes, it is!
You can check the age of the transmission.
The AX-15 production date location is on the bottom where the tranny mount bolts up.
The "304" means '93 (the "3" part) and it was built in April (the "04" part) then the "8152" is the production code number.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
