ax-15 swap question - JeepForum.com
post #1 of 9 Old 08-28-2014, 11:00 AM Thread Starter
coupleofjeeps
ax-15 swap question
I'm buying a rebuilt ax-15 (94-95, external slave) to swap in my 92 Yj. I don't have the time or means to rebuild mine myself, although I'd love the challenge. I'll be doing the swap myself, so my question is:
What else should I consider for this process? I know I need the external slave itself... but seals, or anything else while i'm all tore up??
Thanks in advance...
93 ZJ, 98TJ, 03KJ, 04WJ - SOLD
HIS - 92YJ - mildly built - oh the places we'll go...
HERS - 2002 WJ Overland
coupleofjeeps is offline
post #2 of 9 Old 08-28-2014, 11:51 AM
mrmud4x4
I just did it the swap.
I purchased the Master/slave filled and pre-bleed unit. We were slowed down by that alot. The new master would not fit into the present master cylinder position on the firewall. We modified the new master cyclinder to mount on the present firewall studs.
The new master would not work with my clutch pedal either. The pin on the clutch pedal that attaches to the master cylinder ram was too big, so we drilled the master cylinder ram hole out also.
some careful and precision drilling required.
Of course we replaced the clutch disc, pilot bearing and clutch spring housing too.
Are you getting the ax15 with the proper bell housing setup?
This forum requires that you wait 60 seconds between searches. Please try again in 1 seconds.
mrmud4x4 is offline
post #3 of 9 Old 08-28-2014, 02:17 PM Thread Starter
coupleofjeeps
Did you have the ax15 already? I believe my model year, 92, should be a pretty direct swap. Only difference I can find from reading threads is slave (interval vs. external) everything else should be pretty direct bolt application. I hope at least...
post #4 of 9 Old 08-28-2014, 02:57 PM
hardluk
1987 YJ Wrangler
What motor do you have?
hardluk is offline
post #5 of 9 Old 08-28-2014, 05:57 PM Thread Starter
coupleofjeeps
4.0 i6
post #6 of 9 Old 08-29-2014, 05:48 PM Thread Starter
coupleofjeeps
Any other thoughts?
post #7 of 9 Old 08-29-2014, 06:07 PM
hardluk
1987 YJ Wrangler
Yes it bolts up. There is a parts list in the stickies.
hardluk is offline
post #8 of 9 Old 08-30-2014, 11:27 AM
HuggyBear911
I just did the swap myself...I'm assuming you have a Peugeot BA-10? I got all the conversion stuff from Advance Adapters (AA) and it was an easy process; but not cheap. I think the kit I got cost about $500 from them and includes everything you might need for the swap (less clutch stuff).
AA has the slave and line that works with your exiting clutch master cylinder...or you can modify what you have as already suggested. The trannys are the same length, but the mounting bolts are about an 1.5" further back...again you can get an adapter plate from AA or modify your skid plate (I got the adapter plate). I also got the AA transfer case adapter, but I have read the original can be modified to fit too.
A lot depends on how much you want to spend and how much time and energy you want to invest modifying stuff.
My work number is 9-1-1.
HuggyBear911 is offline
post #9 of 9 Old 08-30-2014, 11:56 AM
timatoe
timatoe's Avatar
Originally Posted by HuggyBear911 View Post
...I'm assuming you have a Peugeot BA-10? .....
If he's got a '92 and the 4.0, he's already got an AX-15. I'm pretty sure the only real "modification" happening here is the external slave, he just happens to be swapping the entire thing including trans. (If I'm understanding it correctly)
timatoe is offline
