AX-15 Shifts No More - Page 2 - JeepForum.com
post #16 of 24 Old 06-25-2011, 10:34 PM Thread Starter
plym49
Originally Posted by Opihi59 View Post
I also have a tendency to "rig for silent running." Meaning I go overboard and fix everything in the system. When I bought my first Jeep and drained the tranny, I got choc. milk/mocha coffee out of it. I pulled it out and rebuilt the entire thing because I didn't know how long it had been that way.
Depending on budjet, resources and time though I am sure you'll make the choice that works for you the best. It's good to have Max onboard though.
It is, and he and I are in contact. Will keep you apprised...............
plym49 is offline
post #17 of 24 Old 06-26-2011, 08:07 PM Thread Starter
plym49
Max has given me the low down (thanks again, Max!!!) in terms of the part numbers I need. In case anyone is interested, they are:
Fifth gear counter P/N 52132.03 (quantity 1)
Fifth gear syncro key P/N 52124.94 (quantity 3)
Fifth gear syncro spring P/N 52154.03 (quantity 2)
Fifth gear bearing P/N 52141.03 (quantity 1)
Fifth gear syncro sleeve P/N 52124.53 (quantity 1)
Fifth gear syncro ring P/N 52125.10 (quantity 1)
plym49 is offline
post #18 of 24 Old 07-15-2011, 09:48 AM Thread Starter
plym49
It's been a while since I've been able to worry about this as my son and I were out west hunting dinosaurs.
Good news: my repair parts have arrived from good old Southwest Gear (thanks again, Max).
Here is a picture of my new fifth gear/syncro assembly shining like Iron Man's palm:
Hopefully repair operations can begin again next week.
plym49 is offline
post #19 of 24 Old 07-16-2011, 05:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sounds great! Please keep the thread updated!
Like Opihi59 said, transmissions are really wonderful pieces of machinery! One of these days I want to assemble an AX5 or AX-15 in a plexiglass case so I can sit it on a bench & use it to demonstrate the wonderful dance that exists between all the components while it's in operation.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #20 of 24 Old 07-16-2011, 09:19 PM Thread Starter
plym49
Max
Will do!
That would be very cool, especially if you could see what happens when you shift.
plym49 is offline
post #21 of 24 Old 07-16-2011, 10:06 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Precisely why I want to do it! I've even considered using a small electric motor to power the input shaft combined with something resembling a bicycle rear coaster style wheel hub. Then I could momentarily kill the power to the electric motor to release the load from the input shaft, much like pressing the clutch pedal releases the load from the engine while shifting.
Max
Mean Max is offline
post #22 of 24 Old 08-10-2011, 03:10 PM Thread Starter
plym49
Back on line! The repairs took a while due to various vacation and travel schedules. Plus, everything was done a couple of weeks ago and on the test drive after a few miles the clutch failed, with brake fluid dripping out from the bellhousing. Yes, a factory defective slave cylinder. As a precaution since everything was apart, we installed a new clutch kit: dick, pressure plate and throwout bearing/slave cylinder. Upon removal and inspection, the new slave had a hairline crack in the housing from the manufacturer.
Returned that to the jobber and got a new one. Put it together, but just let the tranny hang on 2 bolts with everything else still not buttoned up (Jeep was no a lift). Tested the new slave - and again, a leak after repeated applications. Took it apart and - another crack; here was another defective part right out of the box. At this point we figured that we should either reinstall the original, used part (all the original clutch parts we removed looked fine), or get a different brand replacement as we did not want to risk getting another bad part out of what seemed to be a defective lot.
We found a different brand, it all went together, it was again tested before buttoning everything up, and I am happy to say that everything is fine. I put about 50 miles on it today, and the transmission shifted more smoothly than before.
One thing very important with a situation like this is: friends! Whether thru the forum or in person, friends help you get it done. Special thanks to Max, who provided great insights as to the internals of the AX-15, and my best friend whose repair shop did the repairs (and who also lent me his own Jeep so I could complete a scheduled trip with a fully loaded trailer). What a difference friends make.
plym49 is offline
post #23 of 24 Old 08-10-2011, 07:26 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Glad you got it sorted out! Hope I helped at least a little!
I know what you mean about the slave. I just went through that same scenario with defective slaves (from Autozone) but nailed it on the 3rd time. I told the owner of the YJ that I was going to leave the bellhousing bolts out & just use velcro on it.
Max
Mean Max is offline
post #24 of 24 Old 08-10-2011, 07:40 PM Thread Starter
plym49
Max
You helped quite a bit, for which I am extremely grateful.
I wonder what caused the synchro hub to fail in the first place. Could it have been abuse from a prior owner?
The top (shifter) seal was MIA, and when I first got the Jeep and changed the fluids, the tranny fluid was milky (so there was water in there once). Would that have had an untoward affect on the synchro hub? I kind of doubt it.
plym49 is offline
Shifts hard into 2nd Curt99 TJ Wrangler Technical Forum 8 05-10-2012 11:56 PM
No wonder by BA shifts so well still! wendell YJ Wrangler Technical Forum 3 10-23-2010 04:41 PM
Rear End shifts flankgent TJ Wrangler Technical Forum 8 11-10-2009 12:19 PM
clunk during shifts Mcgorty TJ Wrangler Technical Forum 0 11-27-2006 09:44 PM
Still Shifts hard Greenwenie TJ Wrangler Technical Forum 5 06-24-2003 10:38 AM
