I am making the swap from 4 to 6 cylinder. I just bought a used ax-15 trans without a bell housing. Does anybody know if the ax-5 bell housing will mate up to the ax-15 trans? Also some info on changing the input shaft on my transfer case to make the swap complete would help.
Not only will the AX5 bellhousing not bolt to the AX15, it also will not bolt to the 6 cylinder.
You have to get a AX15 bellhousing. If you need one, I have a good used internal slave cylinder version I would sell pretty cheap.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
