AX 15 question - JeepForum.com
post #1 of 3 Old 06-05-2011, 11:24 PM Thread Starter
89yjsahara258
AX 15 question
Hey tried searching but can't find my question. I am wondering what size the upper two bolts that mate the bell housing to the engine are. Tried 10mm socket but is does not seem very snug. What size did you use?
89yjsahara258 is offline
post #2 of 3 Old 06-06-2011, 12:00 AM
Opihi59
from here it gets rough
Opihi59's Avatar
Those are External torx--E12 size. They are a real b**ch to get loose, are very tight and hard to get to. Don't booger them up or you'll regret it. They are best reached from inside the Jeep, thru the shifter hole in the floor with several extensions on your ratchet wrench. Will add in a photo.
The one to the right, almost dead center in the photo. That's the E12 Torx head on the top two bolts of the bellhousing. They are way up high, just below the cylinderhead on the top of the block. Photo is of the driver's side to bolt, they are hard to see so that is the best photo you're gonna get.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #3 of 3 Old 06-06-2011, 12:21 AM Thread Starter
89yjsahara258
Much appreciated.
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
drag link question, and also tyre sizing question snowmanbud TJ Wrangler Technical Forum 3 11-21-2010 07:38 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
