Ax-15 popping out 1st gear - JeepForum.com
post #1 of 8 Old 05-07-2013, 01:25 PM Thread Starter
cj786
I have a 95 jeep wrangler yj 4.0L with the ax-15 transmisson I've recently replaced the transmission with a rebulit one and it works great other than a few issues. When I put it in first gear at complete stop (btw its hard to get it into first gear and second while standing still with the clutch in, like you almost have to force it, it works better if you go from 3-2 then to 1st) and go to take off it pops right out of gear, however, if i hold a little pressure on the shifter and slowly let off of the clutch, it will "click/pop" and from that point it will not pop out. It shifts smoothly through all other gears. It also gives me an issues when trying to go into reverse, feels like maybe the clutch is dragging or something. I would like any help to try and figure the issues or there by chance is a flaw with 1st gear.
Thanks
Jeep supporters
cj786 is offline
post #2 of 8 Old 05-07-2013, 01:46 PM
Kaiser-Willys
I have close to the same issue. My AX15, while cold will go into 1st or 2nd when the tranny is cold. Once it warms up it become a real PITA to get the shifter into those 2 gears when fully stopped. At a slow roll it is easier. I have since replaced & bled the clutch master cylinder and the tranny fluid. Still having the same issue. I again bled the system.......still a PITA to get into 1st & 2nd.
Next step is the syncros?
Kaiser-Willys is offline
post #3 of 8 Old 05-07-2013, 02:17 PM Thread Starter
cj786
I don't think mines the syncros.
cj786 is offline
post #4 of 8 Old 05-07-2013, 03:57 PM
Exit93
i have the same problem with my first gear. everyone has told me its the syncros
Exit93 is offline
post #5 of 8 Old 05-07-2013, 04:25 PM
Kaiser-Willys
Hi all,
I just left a shop where the guy has been a Jeep mechanic for 26 years. He took the Jeep for a drive. When he got back he said he is leaning towards the pressure plate. He has seen a lot of the cheapy, aftermarket clutch kits with weak pressure plates and this problem. He pointed me towards an AC Delco clutch kit or Centerforce.
As for the popping out of gear. There is detent ball that must fit into the detent on the shaft when you place it in gear. Something is worn, sticking or misaligned.
post #6 of 8 Old 05-07-2013, 11:38 PM
jkilmer83
1983 CJ7
With popping out I would say the synco assy not the synco rings. most rebuilds just replace the rings.
1987 yj w/(new)258 .060 over comp cam mc 2150 carb
1989 yj sold
1983 cj7 w/258 t5 dana 300 45k original
mc2100 carb
You just can't fix stupid!!!
jkilmer83 is offline
post #7 of 8 Old 09-02-2013, 03:17 PM Thread Starter
cj786
Update on the. Gearbox was replaced and new one is working like a charm.
cj786 is offline
post #8 of 8 Old 09-02-2013, 06:41 PM
rambo3489
Its the holding teeth/shift collar on whatever gear you are having issues with. They get rounded and don't hold the gear anymore and pop out. Just rebuilt mine and that was my problem. Most people believe it to be the sychros. While they can't help the cause. They won't be solely responsible for it either the holding teeth will be.
EDIT: Sorry to hear you got a new tranny. Rebuilding it is a very big benefit, and honestly not hard to do.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
ax15 , transmission , YJ
