AX-15 manual - JeepForum.com
post #1 of 11 Old 09-17-2011, 11:56 PM Thread Starter
vicsjeep
AX-15 manual
on the way to a trail run today the transmission messed up today. as i came off the highway and tried to downshift it would not go back into a gear. all i have is nuetral left to right. pulled the shift tower but nothing looks out of place. sent it to the transmission shop and had to skip the trail run made that the jeep broke but glad it did not wait till i got back in those steep rocky hills a long way from anywhere. my question is has anyone had this problem, what was it and how much did it cost you. also if this is going to get expencive it might be worth replacing with a new transmission, has anyone had to do this and how much was it?
jacked, shoed, geared, locked, gas tank full...love
vicsjeep is offline
post #2 of 11 Old 09-18-2011, 12:03 AM
444
Had this happen on my peugot trans, turns out the a piece of the shifter itself broke off inside the transmission. I was able to pop the shifter out, fish the piece out of the trans and weld it back together and it's been working fine ever since. Your problem basically has to be something like that or a broken shift fork.
444 is offline
post #3 of 11 Old 09-18-2011, 12:15 AM
Fenix85182
Fenix85182's Avatar
I had the syncros on gears 2 and 4 start to fail, but then my input shaft bearing ultimately went, causing the transmission to be unusable. It cost me $150 for a used transmission that I've got 2 years on.
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #4 of 11 Old 09-18-2011, 12:19 AM Thread Starter
vicsjeep
we looked at what we could see of the forks and did not see anything wrong, that kind of my concern. he's going to have to pull it and take it apart just to see if its worth fixing, maybe i'd be better off if the price was right for a new or rebuilt. pull the old and put in the new, low labor cost.
vicsjeep is offline
post #5 of 11 Old 09-18-2011, 12:26 AM
Fenix85182
Fenix85182's Avatar
I know a place near me where I've gotten a transmission, a motor, and other Jeep parts for cheap. I'm not sure what's available in Oklahoma, but it would be worth looking for a Jeep junkyard to scope out prices.
post #6 of 11 Old 09-18-2011, 01:53 AM
Mark455SD
1961 CJ5
This sounds like the slave cylinder and not the tranny.
Mark455SD is offline
post #7 of 11 Old 09-18-2011, 02:07 AM Thread Starter
vicsjeep
slave and clutch are less than a month old. why do you say that?
vicsjeep is offline
post #8 of 11 Old 09-18-2011, 02:12 AM
Mark455SD
1961 CJ5
Do you have pressure in your clutch pedal? Maybe you got a bad slave. If you cant put the tranny in gear I would check the slave first.
post #9 of 11 Old 09-18-2011, 04:23 AM Thread Starter
vicsjeep
good preasure
vicsjeep is offline
post #10 of 11 Old 09-18-2011, 11:25 AM
Fenix85182
Fenix85182's Avatar
Just to be sure, I'd have someone depress the clutch pedal and you should get under and watch the slave push the throwout lever.
post #11 of 11 Old 09-18-2011, 11:34 AM Thread Starter
vicsjeep
hopefully he will tear into it monday. does anyone know anywhere online they have ordered one from that i can get a idea on a price of a new one?
vicsjeep is offline
Manual Trans blew - I know, why did you get manual... joeranger JK Wrangler Technical Forum 56 12-13-2010 10:25 AM
Service manual, and owners manual Telnet Wrangler General Discussion 3 05-02-2010 06:02 AM
Looking for manual with '97 TJ Jeep Wrangler specs and manual on how to rebuild kgrubb TJ Wrangler Technical Forum 3 04-16-2009 08:50 PM
My manual says to use GL5 in my manual tranny MusicMaverick TJ Wrangler Technical Forum 35 07-24-2008 10:57 AM
whats the difference b/t a factory service manual and factory service workshop manual Johnny World YJ Wrangler Technical Forum 3 03-15-2006 01:01 PM
