AX-15 install problems!!!! - Page 7 - JeepForum.com
post #91 of 111 Old 10-05-2013, 09:23 PM
SamzJeep
Hey Silver. For what its worth. I think you need the tool for the year and vehicle the tranny came out of. I got the tool for the '97 XJ tranny, NOT the tool for my '88 YJ. I first used the tool for the '88 YJ and that ended up being my problem...wrong tool. I think you need the tool for your tranny not your '89 YJ.
SUPPORT OUR TROOPS
SamzJeep is offline
post #92 of 111 Old 10-05-2013, 09:25 PM Thread Starter
silver03cobra
Will do thanks!
silver03cobra is offline
post #93 of 111 Old 10-05-2013, 09:26 PM Thread Starter
silver03cobra
94-99 is the same right?
post #94 of 111 Old 10-05-2013, 09:40 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
You need the 10 spline, 1-1/4" tool, that has a 0.750" pilot tip.
Your '89 would have used the same type of tool, except with a 0.590" tip.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #95 of 111 Old 10-05-2013, 10:08 PM
trboxman
1987 YJ Wrangler
http://www.amazon.com/Lisle-55500-Cl...alignment+tool
$20.00, never have to worry if you have the right size again.
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
- Herbert Spencer
trboxman is offline
post #96 of 111 Old 10-05-2013, 10:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I have the Snap-On version of that, and I don't use it.
For me, the plastic splined tool that comes in a LuK kit just have a better, more positive feel.
Max
Mean Max is offline
post #97 of 111 Old 10-05-2013, 10:12 PM Thread Starter
silver03cobra
Max
I got the 1973 AMC cj5 withe the 304 V8 backed up by the t-15 pilot bushing
post #98 of 111 Old 10-05-2013, 10:18 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Yep, same part number pilot bushing I quoted earlier.
Max
Mean Max is offline
post #99 of 111 Old 10-05-2013, 10:25 PM Thread Starter
silver03cobra
Cool! Thanks for all the help in advance! I told my son (4years old) I would take him out in the jeep the day the trans quite.
post #100 of 111 Old 10-05-2013, 10:42 PM
trboxman
1987 YJ Wrangler
Max
I agree, but when you don't have one this is the next best.
- Herbert Spencer
trboxman is offline
post #101 of 111 Old 10-06-2013, 03:09 PM Thread Starter
silver03cobra
So I pulled the T-case off re did the clutch and had the trans fall on me... getting gas and my lighter ..
post #102 of 111 Old 10-10-2013, 01:27 PM Thread Starter
silver03cobra
Got the tool!! Thanks max!
post #103 of 111 Old 10-10-2013, 04:38 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Very good!
Update the thread when you can!
Max
Mean Max is offline
post #104 of 111 Old 10-11-2013, 02:23 PM Thread Starter
silver03cobra
Toook the day off to fix the jeep.. regret every second of it. Its still not going in.....
post #105 of 111 Old 10-11-2013, 03:33 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Take a breather. Relax.
Go to the hardware store & buy 2 of the longest 7/16" bolts they have. Cut the heads off of both, and then cut slots in the ends where you cut the heads off. Install them into the 3 & 9 o'clock bellhousing bolt holes. This will allow you to put them through the bellhousing & it'll hold up the front of the transmission, leaving you to only tilt the rear of the transmission up & down to achieve alignment.
Have the transmission in 4th gear, so you can twist the output shaft to align the clutch splines.
Max
Mean Max is offline
