AX-15 install problems!!!! - Page 5 - JeepForum.com
post #61 of 111 Old 10-03-2013, 09:10 AM
SamzJeep
When i did mine i had a similar problem. I ended up pulling the tranny out and rechecked the clutch alignment. It was slightly off, so i reset the clutch with that alignment tool. Once i did that, she went right in.
SUPPORT OUR TROOPS
SamzJeep is offline
post #62 of 111 Old 10-04-2013, 08:51 AM Thread Starter
silver03cobra
Will do
silver03cobra is offline
post #63 of 111 Old 10-04-2013, 11:03 AM
SamzJeep
Make sure you're using the correct size alignment tool. I used the wrong size tool and that caused me the problem. Once I figured out the right size tool, she went right in.
SUPPORT OUR TROOPS
SamzJeep is offline
post #64 of 111 Old 10-04-2013, 11:20 AM Thread Starter
silver03cobra
That's my problem... using one for a wrangler... piolt bearing is a different size... what did u use?
post #65 of 111 Old 10-04-2013, 11:42 AM
SamzJeep
I got a tool for the year make of the vehicle the tranny came out of. Mine came out of a '97 XJ, so thats what tool I used for my '88 YJ.
SUPPORT OUR TROOPS
SamzJeep is offline
post #66 of 111 Old 10-04-2013, 07:45 PM Thread Starter
silver03cobra
Sam where do you live in Az?
post #67 of 111 Old 10-04-2013, 08:51 PM
SamzJeep
PM sent
SUPPORT OUR TROOPS
SamzJeep is offline
post #68 of 111 Old 10-05-2013, 12:01 AM Thread Starter
silver03cobra
Thanks for clearing it up... pm u tomorrow
post #69 of 111 Old 10-05-2013, 12:57 PM Thread Starter
silver03cobra
I am about to push this thing out in the middle of the street and set it on fire
post #70 of 111 Old 10-05-2013, 01:06 PM Thread Starter
silver03cobra
Sam where did you get the tool
post #71 of 111 Old 10-05-2013, 01:39 PM
SamzJeep
I ended up getting it at Checker. They actually had to take one out of a '97 XJ clutch kit (the ones that come with the tool). They almost didn't let me borrow one from that kit (which I could understand why), but these guys at this store are pretty cool. I told them that I would only need it for about an hour. So, they let me borrow it. The funny thing (kinda funny) is that on this day it was raining like a *itch outside. I had to re-align my clutch in the pouring rain. I had it done if a couple minutes, re-torqued and all. Then the tranny slid right in. I took the tool back all cleaned up.
SUPPORT OUR TROOPS
SamzJeep is offline
post #72 of 111 Old 10-05-2013, 02:16 PM Thread Starter
silver03cobra
Just re did the clutch still not working
post #73 of 111 Old 10-05-2013, 02:36 PM Thread Starter
silver03cobra
Just re did the clutch still not working... this jeep hates me... I knew I should have stayed with mustangs
post #74 of 111 Old 10-05-2013, 02:49 PM
imstillatwork
The only places that will prevent the transmission from mating are
* the alignment pins on the bellhousing (or on the block, depending on where they stayed during separation)
* the input shaft / clutch disk splines
* the input shaft length
* the pilot bearing
You can verify all of these by measuring with the transmission off. Or you can test fit things to rule out issues.
1) Have you slipped the clutch disk over the input shaft to verify it fits without sticking or binding?
2) Have you test fit the pilot bearing on the end of the input shaft?
3) Have you checked that there isn't something behind the pilot bearing that is preventing the input shaft from seating all of the way?
4) Have you test fit the bellhousing without the clutch/pressure plate installed to verify the shaft is not too long or pilot bearing issues?
It sucks that it's giving you so much trouble, but there must be at least ONE thing that is not right. we have to narrow it down by proving everything that you can and see what's left.
imstillatwork is offline
post #75 of 111 Old 10-05-2013, 04:12 PM Thread Starter
silver03cobra
Input shaft too long would be it... but no one has the same problem
