AX-15 install problems!!!! - Page 4 - JeepForum.com
post #46 of 111 Old 09-30-2013, 04:29 PM Thread Starter
silver03cobra
OK I will try that... I have a trans jack and have jacked up the motor a bit
silver03cobra is offline
post #47 of 111 Old 09-30-2013, 05:06 PM Thread Starter
silver03cobra
Well can't slide it all the way in or out... its just tight I guess.. will keep on it
post #48 of 111 Old 09-30-2013, 05:31 PM
jeep108
Did you by chance test fit the pilot bushing on the input shaft of the trans before you installed it?
And did you get the pilot bushing seated flush in the crank?
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #49 of 111 Old 09-30-2013, 05:43 PM Thread Starter
silver03cobra
Yes to both
post #50 of 111 Old 09-30-2013, 08:25 PM
jeep108
Have you tied talking sweetly to it? i feel your pain, typically nothing goes the way it is supposed to when i do something to the heep, thats why i've adopted the "Just Expect Every Problem" philosphy.
jeep108 is offline
post #51 of 111 Old 10-01-2013, 07:19 AM
rodgers3
I bought some 6in long bolts with the same thread as the ones on the bell housing and used them as alignment "pins" it worked great and reuired much wiggling and fighting..good luck!
rodgers3 is offline
post #52 of 111 Old 10-02-2013, 04:17 PM Thread Starter
silver03cobra
It looks like my internal slave is touching the presser plate. But I have about 1/2 an inch left
post #53 of 111 Old 10-02-2013, 04:59 PM
SamzJeep
Did you put a new slave in? The new ones come with some retaining straps that hold the throwout bearing back until you depress the clutch after it's all installed
SUPPORT OUR TROOPS
SamzJeep is offline
post #54 of 111 Old 10-02-2013, 05:22 PM Thread Starter
silver03cobra
No didn't running out of time!!!! Needs to be done and tested by tomorrow
post #55 of 111 Old 10-03-2013, 06:39 AM
rodgers3
Just a long shot here but maby you have to take hydraulic pressure off the slave to allow it to compress the rest of the way?
rodgers3 is offline
post #56 of 111 Old 10-03-2013, 07:40 AM
bigbossd1030
Iirc there isn't any pressure in the line unless you press the pedal. If you pull the line, it will drain the master, gravity though. He should be able to push the rod back in, unless the lid is sealed tighter than a nun.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #57 of 111 Old 10-03-2013, 07:53 AM
rodgers3
Oh, duh. I was thinking maby it wasnt allowing the slave to be compressed at all.
rodgers3 is offline
post #58 of 111 Old 10-03-2013, 07:57 AM
bigbossd1030
well I could be wrong, I've never had the lower connection off. And bleeding the pedal is always pushed in when I open the bleeder. So if someone knows for sure. Please let us know.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #59 of 111 Old 10-03-2013, 08:41 AM Thread Starter
silver03cobra
I opened the bleeder... still not working
post #60 of 111 Old 10-03-2013, 08:43 AM Thread Starter
silver03cobra
I have done 6-7 transmissions in my life (mustang) this jeep reinstall is killing me!
