AX-15 install problems!!!! - Page 3 - JeepForum.com
post #31 of 111 Old 09-25-2013, 07:44 PM Thread Starter
silver03cobra
Ace hardware 8.00+ metal chisel... I will be in crown king with my chilli on Oct 5th!!!!
silver03cobra is offline
post #32 of 111 Old 09-25-2013, 08:25 PM
rambo3489
Yea. It's around 10* I think it's actually a little more. Those pilot bearings can be a pain. I used the grease trick the first time. That took a while. But worked. Tried it the second time. Said screw it and got the tool from AZ. Had to modify the tool a bit to get it to work
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #33 of 111 Old 09-25-2013, 09:43 PM
SamzJeep
I took my pilot out with a small slide hammer. Came off easy.
SUPPORT OUR TROOPS
SamzJeep is offline
post #34 of 111 Old 09-26-2013, 07:37 AM Thread Starter
silver03cobra
Not this one..
post #35 of 111 Old 09-26-2013, 02:20 PM
rambo3489
The slide hammer with pilot bearing attachment worked great for me as well. It will come out with enough determination.
<a href="
THE YJ MY WAY</a>
post #36 of 111 Old 09-26-2013, 05:10 PM Thread Starter
silver03cobra
Looks like I need a clutch
post #37 of 111 Old 09-26-2013, 05:55 PM
SamzJeep
It's good to get a new clutch and pressure plate anyways since you have it all apart. You get a new throwout bearing too? If not, you should. My 2 cents. Good luck....
SUPPORT OUR TROOPS
SamzJeep is offline
post #38 of 111 Old 09-26-2013, 06:16 PM Thread Starter
silver03cobra
Thought with an internal slave it was attached
post #39 of 111 Old 09-26-2013, 06:21 PM
SamzJeep
Oh, i didn't know you had an internal slave. If your internal slave is new, you're good to go. I thought you put in a newer tranny with external slave.
SUPPORT OUR TROOPS
SamzJeep is offline
post #40 of 111 Old 09-26-2013, 09:10 PM Thread Starter
silver03cobra
Yea.. cash was (is) tight so I didnt want to buy a fork and such... now I need a clutch... BTW pilot bearing is still not all the way out.. think it was jb weld or lock tight..
post #41 of 111 Old 09-26-2013, 09:12 PM Thread Starter
silver03cobra
$1,500.00 for a jeep..... 2,000.00 to get it moving after 10k miles
post #42 of 111 Old 09-26-2013, 09:18 PM Thread Starter
silver03cobra
Jeep has just a little more to go.... not BAD for $1,500.00
post #43 of 111 Old 09-26-2013, 09:26 PM Thread Starter
silver03cobra
Sorry for big pictures
post #44 of 111 Old 09-30-2013, 12:30 PM Thread Starter
silver03cobra
This transmission still won't go in!!! Wtf! Are the input shafts longer?
post #45 of 111 Old 09-30-2013, 01:07 PM
jeep108
Shouldn't be. I just put mine in yesterday. Fought all day saturday trying to get it in using rachet straps and brute force, sunday I sucked it up nd bought a transmission jack, had it in under 30 min. I did have to jack up the motor a little to get to all line up but it went in with just a little wiggling. The way i finally got my angle right was to put the bolts in each side of the tranny and nudge them up against the block, then make adjustments until the bolts looked level with the holes in the bolck. Also make sure the tranny is in gear so you can move the output shaft to get the input shaft to line up with the clutch
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
